Engine Vibration - Team Camaro Tech
post #1 of 12 (permalink) Old Oct 6th, 06, 08:18 AM Thread Starter
Engine Vibration
69 with 350 has a engine vibration @ 3500rpms and up.
Does it ata stop in neutral as well as on the road.
All comments welcome
Schoon
SCHOON is offline
post #2 of 12 (permalink) Old Oct 6th, 06, 08:38 AM
Chris
Re: Engine Vibration
I always like to start at the front of an engine and work my way back; so the first thing I'll throw-out on the floor is torsional damper i/e harmonic balancer. could be loose on the crank, or the rubber membrane is starting to separate from between the halves.
how noticeable is the vibration ?
'69 SS X66 Camaro
454, TH400 & GearVendor, 12 bolt
'82 Corvette.
stock
'81 Camaro Pro Bracket car.
406, TH350, 10 bolt, NHRA #3148
82Vettrin is offline
post #3 of 12 (permalink) Old Oct 6th, 06, 08:44 AM Thread Starter
Very noticable but only starts at 3500.
I am thinking the same as you but I was hoping for something simple
Schoon
SCHOON is offline
post #4 of 12 (permalink) Old Oct 6th, 06, 08:55 AM
Chris
the old-type balancers that were spoked inside, you could pretty much look at them and tell. but if you've got the newer type like comes on the ZZ engine, unless you can see the rubber-ring poking out or something, it's almost a process of elimination-by-replacement,, and I HATE that process.....
'69 SS X66 Camaro
'82 Corvette.
stock
post #5 of 12 (permalink) Old Oct 6th, 06, 09:00 AM Thread Starter
I should have mentioned this problem is on a different engine not the one in my Z.
This is a 78-79 350 in my 74 Vet.
I haven't replaced one of these in a very long time.
Can you please tell me what is involved or point me in the right direction.
Schoon
SCHOON is offline
post #6 of 12 (permalink) Old Oct 6th, 06, 10:01 AM
Chris
ouch.. Corvette. nothing is easy on a 'Vette, especially in the engine compartment. I've not done this job either, but do have a buddy on a Corvette forum who has. I can hook you up with him if you'd like, or wait and see what others have to offer here.
'69 SS X66 Camaro
'82 Corvette.
stock
post #7 of 12 (permalink) Old Oct 6th, 06, 12:39 PM Thread Starter
Please hook me up with your Bud. I also hangout on the Corvette Form under Schoon.
I have this question posted on there as well.
Thanks!
Schoon
SCHOON is offline
post #8 of 12 (permalink) Old Oct 6th, 06, 03:24 PM
Chris
sent you a PM for the hook-up.
'69 SS X66 Camaro
'82 Corvette.
stock
post #9 of 12 (permalink) Old Oct 6th, 06, 04:41 PM
Rex
What kind af transmission are you running. I had the same problem at it was my centerforce clutch. the springs open at around 3k. I changed the clutch and no more vibration!
69 x-11..LS1, 420.88 horse to the tires,750 Holley Ultra DP, Torquer V2, darksides headers, PRC heads, 10.8:1 compression, forged bottom end, 5 speed. 2008 King Ranch F150 4x4.
trex70 is offline
post #10 of 12 (permalink) Old Oct 6th, 06, 06:34 PM
Yeah, hopefully it's clutch or flexplate related. Easy fix.
Dave F. in Rhode Island
Chevy-SS is offline
post #11 of 12 (permalink) Old Oct 8th, 06, 12:33 PM Thread Starter
4 speed Muncie.
Had the vibration beofre I added the new Centerforce Clutch the other day.
Schoon
SCHOON is offline
post #12 of 12 (permalink) Old Oct 9th, 06, 04:33 PM
Steps
Was the engine crank, flywheel, clutch, pressure plate, pistons crank, rods all balanced?
Many ppl think just because a engine is going to be for street use, one doesnt have to bother....it makes a huge diff to comfort and the long lasting of the engine.
Worth every penny every time
Steptoe is offline
hi performer engines jdbr1 Engine 7 May 28th, 07 05:56 AM
engine help RJBaileyrn Engine 1 Aug 12th, 06 10:26 AM
bad engine/ transmissiom?? vibration rockin rollin Troubleshooting 10 Jun 22nd, 06 06:56 PM
What engine is this inside of my 67 Camaro?? camaro_town Tag Team 3 Apr 23rd, 04 05:14 PM
yet another ENGINE vibration question Spames Engine 9 Jan 25th, 02 12:59 AM
