Help! engine lacks power has a strong exhaust odor - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 10th, 06, 10:14 AM Thread Starter
Unhappy Help! engine lacks power has a strong exhaust odor
I have a 1994 Camaro with a 3.4L V6. It has an overwhelming exhaust odor coming from under the hood, it's loud when I accelerate and lacks power, like your starting off in second gear. The egr valve had started melting (the plastic) and the plug wire near the valve had melted as well as the plastic wire harness protectors. I replaced the egr valve and it had become so hot it had cracked the metal on the egr valve's mounting plate (not the manifold). It still has the strong exhaust odor and no power? Can anyone help diagnose this?
pwardon3 is offline
post #2 of 3 (permalink) Old Oct 10th, 06, 10:35 AM
Re: Help! engine lacks power has a strong exhaust odor
Maybe it's just getting old, I have the same symptoms....
onovakind67 is offline
post #3 of 3 (permalink) Old Oct 10th, 06, 11:19 AM
ZZ_430's Avatar
LOL onovakind67.
About the 94, sounds like a possible plugged cat converter.
It should be taken to a shop that can do a pressure drop test on it, but there is a backyard test.
Attach a vacuum gauge to a ported source, and rev engine over 2500 RPM. If the vacuum doesn't rise but continues to fall, there is a restriction in the exhaust.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
Lifter adjustment, warm or cold? gotsnappy Engine 32 Apr 20th, 06 06:41 PM
Strong Gas Odor Tim Meadows Troubleshooting 10 Jul 14th, 05 06:39 AM
interpret my time slips...whats happening? BBC1 Performance 60 Jul 12th, 05 08:15 AM
95 Z28 Low RPM engine stumble, runs strong above 3,500RPM's 95 LT1 Z28 Performance 8 Sep 4th, 03 03:17 PM
Vacuum Question Ken Davidson Performance 44 May 11th, 01 07:18 PM
