Burning up electric fuel pumps... - Team Camaro Tech
post #1 of 15 (permalink) Old Oct 18th, 06, 01:39 PM Thread Starter
I've now gone through my second Holley electric fuel pump. The motor has less than 100 miles on it. The pump is mounted in front of the rear differential at the lowest point possible against the underbody. I have a nice big fuel filter between the stock tank and the pump. Could it be that it is a gravity fed pump and it runs dry using the stock tank in its stock location?
Thanks,
Gary V.
vfam3 is offline
post #2 of 15 (permalink) Old Oct 18th, 06, 01:53 PM
Re: Burning up electric fuel pumps...
Those pumps are cooled by the fuel, but you have to have flow for that to happen. Suggest you put in a bypass regulator and a return line, that will keep the fuel moving and the pump cool.
post #3 of 15 (permalink) Old Oct 18th, 06, 03:01 PM
click's Avatar
Any chance you have the power lead ON all the time, even with key off? I burned mine up by forgetting to disconnect the power to it when I had it as a temp pump on vacation.
JimM knows my fuel pump intimately too
click is offline
post #4 of 15 (permalink) Old Oct 19th, 06, 09:39 AM Thread Starter
Thanks, I suspect it is, indeed, a cooling issue. I'll do a search on configuring your suggested set up.
vfam3 is offline
post #5 of 15 (permalink) Old Oct 19th, 06, 09:43 AM Thread Starter
I don't think so. I have a toggle switch handling the power. Thank you for your thoughts.
vfam3 is offline
post #6 of 15 (permalink) Old Oct 19th, 06, 10:51 AM
Banned
Rob
satz28's Avatar
Thanks,
Gary V.
Is the pump designed to overcome the resistance of the fuel filter?
satz28 is offline
post #7 of 15 (permalink) Old Oct 19th, 06, 11:31 AM
Chris
what size wire supplying power, and are you running the power thru a relay and not directly thru the switch itself ?
low/reduced voltage will burn-up a hi load demand appliance.
'69 SS X66 Camaro
454, TH400 & GearVendor, 12 bolt
'82 Corvette.
stock
'81 Camaro Pro Bracket car.
406, TH350, 10 bolt, NHRA #3148
82Vettrin is offline
post #8 of 15 (permalink) Old Oct 19th, 06, 03:04 PM Thread Starter
Will I need to weld in a return inlet?
vfam3 is offline
post #9 of 15 (permalink) Old Oct 19th, 06, 03:13 PM
You'll need to add one if there isn't one there.
JB weld or epoxy will hold it fine, but the tank will need to come down.
post #10 of 15 (permalink) Old Oct 19th, 06, 04:43 PM Thread Starter
Sounds like a project I can handle. Thank you very much!
vfam3 is offline
post #11 of 15 (permalink) Old Oct 20th, 06, 02:37 PM
As stated, I bet a return line fixes you right up, plus you will need the proper pressure regulator (also as stated).
I put Accel DFI on my '68 and I plumbed the return line using an additional steel line, which I routed into the filler neck with a 90 degree brass fitting. Works real good.
I also mounted the fuel pump using a bracket mounted on rubber isolators, then I wrapped Dynamat around the pump (only the clamping area) itself, so that when I tighten the stainless hose clamps, the clamps are against the Dynamat material. This reduced the fuel pump noise to almost nothing. Some of those electric fuel pumps can get really loud when mounted right to the chassis!
Dave F. in Rhode Island
Chevy-SS is offline
post #12 of 15 (permalink) Old Oct 20th, 06, 04:23 PM
Bill
1.) Use a return line
2.) Use a relay and good quality wire
WildBillyT is offline
post #13 of 15 (permalink) Old Oct 24th, 06, 09:17 AM
Summit carrys a part that attaches between the fuel tank and the filler neck where you could attach your fuel return line. Youll probably still have to drop the tank to access it though.. I havnt used it but seen it in anouther thread..
Long Gone: 1984 Z28, 1989 RS
Current : 1967 Coupe w/350, 2010 2SS
My Photobucket >>
dragon0123 is offline
post #14 of 15 (permalink) Old Oct 24th, 06, 03:36 PM Thread Starter
Just got off the phone with Summit and got the new pump, return kit and relay kit on the way. Thank you. I'm sure this will solve all issues and I can burn rubber with confidence!
vfam3 is offline
post #15 of 15 (permalink) Old Nov 8th, 06, 05:20 PM
jim
I hope you NEVER, NEVER, NEVER use the toggle switch as the master power off. VERY dangerous and against all safety rules of every organization and track everywhere. If you get in an accident or a fire breaks out the ignition switch (and rear cutoff if a race car) must be able to stop all electric current to the ignition and fuel system. Its ok to use the toggle as a 2ndary switch but it must be behind the key switch. You dont want the pump to keep on shooting fuel into an engine bay that might catch on fire.
baracda is offline
Electric Fuel Pump 86 Camaro robbigdog Camaro Tech 2 Oct 13th, 05 05:03 PM
Fuel pump is dead, EFI pumps reliable/good? 67RS502 Performance 3 Jan 20th, 05 02:59 AM
mounting electric fuel pump??? BBCamaro Performance 6 Feb 9th, 03 08:51 PM
Electric Fuel Pump 2zMax Engine 9 Feb 22nd, 02 08:30 AM
electric fuel pump===> mechanical help! rogleete Troubleshooting 4 Jan 1st, 02 09:25 AM
