No Idle - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 21st, 06, 09:47 AM Thread Starter
No Idle
When car is warmed up it idles around 7. When I take off and come to a stop the idle goes to 0 and I stall out.
The carb is a Holley DP and is 1 year old.
When I have the filter off and the car is idling one of the rear jets is dripping gas down into the carb. When I rev it the front jets spray good and the backs do ok.
It is a 350 engine with a Muncie 4 speed.
This problem started the other day when I adjusted the idle screw down a bit.
Schoon
SCHOON is offline
post #2 of 3 (permalink) Old Oct 21st, 06, 12:45 PM
Steps
Re: No Idle
Check your float heights...
With the level screws removed, there should be no fuel come out...when y bump or shake the car, u should see a small spill over.
Check no crap in the valves.
Steptoe is offline
post #3 of 3 (permalink) Old Oct 22nd, 06, 07:29 AM Thread Starter
Re: No Idle
Thanks that was the problem.
When I opened up the back site plug the gas poured out.
This carb is only 3 years old and is a Holley 4777S and all of the nuts and screws were loose. Had to go over everything real close.
Schoon
SCHOON is offline
850 DP hesitation Mister G Performance 21 Dec 18th, 06 07:19 PM
Initial timing setting? RRatchet Performance 4 Feb 6th, 06 09:13 AM
Holley tuning? railing68 Performance 22 Feb 13th, 05 03:55 AM
Holley tuning question wizard67 Performance 22 Sep 20th, 04 04:05 PM
My 1st Big Cam/ Trying to adjust Carb/Low Vacuum PERKS67-396 Engine 20 Oct 4th, 02 09:14 AM
