starting proublems 1996 z28 lt1 - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 31st, 06, 02:38 PM Thread Starter
guy
when i unlock the doors i get a cliking noise from the factory alarm and when you turn the key you get nothing or it will turn over but the fuel pump wont turn on or it wil start right up but if you dont lock the doors it will start right up it takes about 24 hours to start if i lock the doors i think its the security system but dont know how to check it
hillbilly guy is offline
post #2 of 2 (permalink) Old Nov 3rd, 06, 11:45 AM
Kevin
SixtyAte's Avatar
Re: starting proublems 1996 z28 lt1
You may have a bad BCM (Body Control Module). The starter enable circuit controls the theft deterrent relay. When the BCM sees the proper resistance at the ignition key, it grounds the starter enable circuit which allows the engine to be cranked. If the BCM does not sense the proper resistance at the ignition key, it will not ground the starter enable circuit. Have the system checked for the codes if any and see if its a bad BCM
SixtyAte is offline
1970 Z28 Lt1 69z28freak Engine 0 May 25th, 06 09:24 PM
96 Z28 not starting JJWaiters2 Troubleshooting 5 May 5th, 06 10:25 AM
1997 camaro z28 brickyard lt1 convertible supercomp Bench Racing 2 Dec 11th, 05 06:34 PM
69 z28 starting issues Cpz28 Electrical & Wiring 6 Oct 28th, 05 02:41 AM
85 Z28 not starting Crazy Rusty Electrical & Wiring 8 Apr 28th, 05 07:22 PM
