67 horn - Team Camaro Tech
post #1 of 5 (permalink) Old Nov 7th, 06, 01:24 PM Thread Starter
Randy
Send a message via MSN to loki4_31
67 horn
i cannot get my horn to work. i have a delux steering wheel with the correct horn contact hardware. if i push the horn button nothing happens. the only way to get the horn to work is if i remove the steering wheel and touch the brass horn contact button that sits in the turn signal can with a hot wire. if i am not mistaken, when i push the horn button, the concave metal plate behind the button should flatten out, press the metal rod wich sits inside a nylon sleeve. that rod pushes on a spring that runs through the steering wheel and pushes on a plastic disc with a metal backing. that disk pushes another rod down on a spring that is touching the wire that runs to the horn. so the metal plate that is flattened out should ground itself on the steering wheel which completes the circuit. but it is not grounding out somewhere. any ideas?
loki4_31 is offline
post #2 of 5 (permalink) Old Nov 7th, 06, 05:25 PM
Paul
Re: 67 horn
I had a lot of issues getting mine to work too.
If you push on the concave metal piece w/out the horn button on, can you get it to ground out and make the horn beep?
You may have an issue with the plastic insulator not allowing the concave plate to ground out and set off the horn. The factory assembly manual has a decent picture of how the whole thing needs to go together
1967 Camaro RS 350, Tremec 5spd, Hotchkis, Frame off
Bought it
Rebuilt it
Almost done
oakster is offline
post #3 of 5 (permalink) Old Nov 8th, 06, 05:19 AM
Re: 67 horn
Just to make things clear. When you say that you touch the brass horn contact button with a "HOT" wire. I think that you mean that you touch the contact button with a wire that is connected to a grounded body part, the horn blows. (This is the way it is supposed to work. Completing the ground should close the horn relay and blow the horn.) The following is a scan from a Corvette AIM. It isn't exactly the same as your Camaro but it should be close.
Even though the contact button (#7 Eyelet) is spring loaded. It really doesn't move at all when you press on your Horn Cap #1. It should always be in contact with a leg of the horn Contact Assembly #5. When you press on the horn cap you should complete a circuit down through the steering wheel hub, down through the steering column shaft, down through the flexible coupling, down through the steering gear, into the frame, and back to ground.
You might try this. Go out under the hood. Connect one end of a wire to a grounded part under hood. Now take the other end of the wire and touch the steering shaft where it exits the steering column. See if the horn works. If it does, that could mean that you do not have electrical continuity through the flexible coupling. Some replacement or rebuilt flexible couplings do not have a ground wire (or a metal mesh screen in the rubber disc) to provide a ground path.
Lastly, this is a pretty good paper on Horn Operation Diagnosis.
http://jimshea.corvettefaq.com/wp-co...ACar13JN06.doc
Hope that this helps.
JIML82
JIML82 is offline
post #4 of 5 (permalink) Old Nov 8th, 06, 09:41 AM Thread Starter
Randy
Re: 67 horn
thanks for the advice but still no dice. i tried grounding the steering coulmn but it had no effect. the only time the horn will blow if i i run a wire from the battery to the brass contact buttom sitting in the turn signal cam. i do not think it is making contact with the plastic, brass backed plate that parts # 6, 7, and 8 sit in. i assumed the steering colmn was not grounded. but if i touch a wire to the nut that secures the steering wheel in place, and touch the other end to the the contact plate there is a light spark and there is a clicking sound comming from the horn relay. but nothing happens when i run a wire from the battery and touch the contact plate.
loki4_31 is offline
post #5 of 5 (permalink) Old Nov 8th, 06, 10:16 AM Thread Starter
Randy
Re: 67 horn
the horn only works when i run a wire from the battery and touch the contact plate.
loki4_31 is offline
Horn Button on '67 Deluxe Wood Wheel? SFCamaro Electrical & Wiring 8 Oct 23rd, 06 09:06 PM
67 SS Steering Wheel Horn Countryside_Cafe Body Shop 0 Aug 14th, 06 06:27 PM
67 deluxe horn assembly diagram/help needed 67FamilyFun Electrical & Wiring 7 Aug 2nd, 06 05:17 PM
67 horn relay bad? GMJoe Electrical & Wiring 0 Jun 12th, 06 01:50 PM
Help with '68 Wood Steering Wheel Horn Cap Installation on a Tilt column ggkeller Interiors 2 Jun 29th, 05 05:32 PM
