canister inside the drivers side fenders? - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 8th, 06, 04:01 PM Thread Starter
What is the vacuum canister inside the driver side fender of my 68 do? I had AC once so I dont know if it went to that and I now can get rid of it?
wheezer is offline
post #2 of 3 (permalink) Old Nov 8th, 06, 04:30 PM
click's Avatar
Re: canister inside the drivers side fenders?
the canister is part of the a/c system. It activates when you slide the dash panel knob into A/C, it then sends vacuum to that canister and then the vacuum goes to the passenger side inner fender to a heater cut off valve, which then closes to keep heat from going thru the heater core while in A/C mode. As long as the source of Vacuum to the dash panel is plugged or not hooked up at all, you wont have an issue. If a Vac hose is open it will affect the engine vacuum since its open all the time while running.
click is offline
post #3 of 3 (permalink) Old Nov 8th, 06, 04:32 PM
Kevin
SixtyAte's Avatar
I believe the canister is for the A/C system.
Kev
SixtyAte is offline
Drivers side quarter brace Mark .L.W. Body Shop 9 Apr 27th, 04 01:07 PM
Inside of front fenders and valance, what color? jeff1969rs Body Shop 4 Aug 13th, 03 04:43 PM
What color to paint inside of front fenders? jeff1969rs Body Shop 4 Jan 3rd, 03 05:30 PM
Painting Inside of Front Fenders? bowtie_bruce Body Shop 2 Apr 26th, 02 07:57 AM
Unlocking drivers side door?? pdq67 Body Shop 12 Apr 19th, 01 02:18 PM
