ecm high voltage 89 camaro 2.8 mpfi - Team Camaro Tech
post #1 of 9 (permalink) Old Nov 18th, 06, 06:44 AM Thread Starter
check engine came on, code 34 replaced maf sensor, code came back, checked voltage at maf sensor plug middle wire, read 10.3 volts, should be at 5 volts ?, checked wire for short to voltage (test lite from middle plug in to ground, no lite) = bad ecm replaced ecm check eng lite off now but middle plug in on maf plug in still reads 10.3 volts help?
jeff mushrush is offline
post #2 of 9 (permalink) Old Nov 18th, 06, 12:45 PM
Re: ecm high voltage 89 camaro 2.8 mpfi
You might want to unplug the MAF connector and check continuity from the ECM connector to the MAF connector and to ground. Five volts goes out to semsor, any one of them, goes through the circuit, whatever it might be, and the return to ECM to tell ECM the condition is being sensed. There should be a minimal amount of voltage to chassis ground, and this difference should be seen on 5 volt reference voltage also. The ECM provides its own ground for the sensors. None get referenced to ground.
Also, check 5.0 volt at other sensor connectors to see if 5 volt regulator is broke or has a bad ground. Check all grounds in engine harness and ECm ground(s).
Welcome to the site, also.
post #3 of 9 (permalink) Old Nov 18th, 06, 01:51 PM Thread Starter
Thanks for the info. Gonna go check things out and will get back to you in the next day or two. thanks again..
post #4 of 9 (permalink) Old Nov 18th, 06, 02:22 PM
Good luck. I'm sure you've tried over at www.thirdgen.org
post #5 of 9 (permalink) Old Nov 20th, 06, 07:39 AM
I have seen the connector pins loose their tension and not make good contact on than generation of MAF sensors. But the 10.3 volts has me stumped. The voltage should be 5 volts that the ECM supplies to the plug and the MAF will pull the voltage down to ground. At least this is true for voltage control MAFs. I'm not sure what the requency control MAFs have for a voltage signal, but I'd presume 5V as well.
Have you tried measuring that voltage with the MAF disconnected? I'm just wondering if the MAF is supplying the 10.3 volts or if it is in fact coming from the ECM / wiring.
dnult is offline
post #6 of 9 (permalink) Old Nov 23rd, 06, 04:30 AM Thread Starter
wellll, sorry for the question, my stupidity reigns here.started checkingbattery & alt put volt meter on battery read 25 volts had volt meter set on wrong setting sooo apologies do appreciate all help thanks
post #7 of 9 (permalink) Old Nov 23rd, 06, 04:51 AM
But you learned something. You're welcome.
post #8 of 9 (permalink) Old Nov 24th, 06, 08:33 AM
No worries Jeff. So do you see 5V at those points instead now? I presume you've got a code set still. Let's just move on and pretend like the meter thing didn't happen.
dnult is offline
post #9 of 9 (permalink) Old Nov 25th, 06, 04:10 PM
george
It is not uncommon for the 5 volt referance line to share common sensors.Look for other 12 volt sources that can leak into the 5 volt ckt inside connectors.Under car is usually the first place to start.For example,running only a fuel pump 12 volt supply can run to a 5 volt referance if moisture has contaminated the common connector.An ac pressure sensor can also contribute to this.I would look at a schematic and try to link the ckts.Good luck.George
fatblock is offline
Where is the voltage regulator on Camaro? Machineh3d Electrical & Wiring 2 Oct 16th, 04 06:10 PM
Coil Primary Voltage Too High? Nicky Electrical & Wiring 6 Feb 17th, 04 01:16 AM
Pertronix and MSD with High voltage coil ?? Joe Harrison Engine 1 Oct 17th, 01 06:22 PM
'69 Camaro Voltage Regulator Problems mrdani Troubleshooting 5 May 14th, 01 06:18 PM
1994 Camaro Z-28 High Idle Problem WRaynor482 Troubleshooting 9 Feb 23rd, 00 06:30 PM
