93' Camaro smoking black, fowling plugs - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 20th, 06, 04:04 PM Thread Starter
I just bought the 93' Camaro, and the problem is it runs great after putting a new set of plugs in. Then after about a few minutes of idol it begins to smoke black , run rough, then knocks off. I look at the plugs and it is obvious that it is over load with gas. I want to change the ecm or computer but is this jumping the gun. It has a new fuel pump and coil pack. But this is all I know about the car. Motor sounds good until it fowls out. Runs strong but did notice it didn't want to pull in gear, another reason I beleive I should replace ECM. Anyone that has a suggestion I am open to anything at this point, as you know this part is expensive and I don't want to jump the gun if it could be something else.
shadowone is offline
post #2 of 2 (permalink) Old Nov 20th, 06, 06:44 PM
Smile Re: 93' Camaro smoking black, fowling plugs
you need to check codes in your computer. get a manual for your car if you want to fix it yourself, it will be your best tool. if it is doing it from the get go, meaning it is running rich all the time even cold, even hot, and it runs good until it fouls the new plugs out, then i'd check for leaky injectors. is it hard to start cold? does it smoke black when driving or only at idle? the check engine light should be on, mabye even flashing. there has to be codes in there to help you. look under the dashboard. you'll see a black connector bolted to the trim. this is where you read codes from. there will be 12 pinholes. the last two on the top right of the conector is where you need to look. take a piece of wire and jump these two terminals. turn the key on and your check engine light will flash the codes. this is why it is necessary to have the book. it will define the codes for you as well as give you an illustrated description as to what i am talking about. just a cheap haynes manual will do. get back with us
nate is offline
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 07:37 AM
Black Widow spider damages Camaro 383 Bench Racing 39 Mar 31st, 04 06:13 AM
Rhonert Park Camaro Results Ed Ernst Bench Racing 9 Jul 11th, 01 07:59 AM
black plugs baddasss1 Troubleshooting 8 Mar 22nd, 01 11:22 AM
Are 69 Camaro console gauge faces silver or black? Camaro68luvr Tech 2000 5 Feb 6th, 01 10:46 AM
