timing problem maybe?? - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 26th, 06, 06:21 AM Thread Starter
my 91 camaro rs with a 305 tbi is running real rich and popping out the exhaust, from reading here it sounds like maybe timing, can anybody help? mike
mike_o is offline
post #2 of 8 (permalink) Old Nov 26th, 06, 07:07 AM Thread Starter
Re: timing problem maybe??
anybody??
mike_o is offline
post #3 of 8 (permalink) Old Nov 26th, 06, 09:40 AM
you need to check for codes. I'll bet it's got a sensor gone wacko and it's in "limp home" mode.
post #4 of 8 (permalink) Old Nov 26th, 06, 12:55 PM Thread Starter
i just put in a new o2 sensor, so i guess i will take your advice and check the codes, thanks alot. mike
mike_o is offline
post #5 of 8 (permalink) Old Nov 26th, 06, 01:24 PM Thread Starter
ok i checked the codes, my service engine light is flashing once, then two real fast flashes, does anybody know what this means? i dont have a book. mike
mike_o is offline
post #6 of 8 (permalink) Old Nov 26th, 06, 06:50 PM
Mike.......When the light flashes once and then two quick flashes, that is a normal sequence that shows your ECM is working properly. It will flash this sequence three times followed by any trouble codes then close with the same sequence of flashes. Check your timing with a timing light......I believe it should be around 14 deg BTDC. Disconnect the spark advance plug near or above the AC unit before you check the timing and don't forget to reconnect it afterwards.
Camaro buds until the end!!!
Camaro Dave is offline
post #7 of 8 (permalink) Old Nov 30th, 06, 04:25 PM Thread Starter
camaro dave, exactly where is this line i need to unplug???? mike
mike_o is offline
post #8 of 8 (permalink) Old Nov 30th, 06, 04:27 PM Thread Starter
camaro dave, probley not the right way but i timed her by ear and i have gotten rid of alot of the popping out the exhaust, for a 305 she runs strong...
mike_o is offline
Pertronix and Timing Golden69 Electrical & Wiring 6 Apr 4th, 06 11:02 AM
How to set timing? cradfordchevy1 Performance 4 Oct 26th, 05 04:54 PM
327 won't start now....timing problem? Granny's 69 Engine 17 Jul 5th, 04 11:31 AM
Timing Problem??? Bantam Troubleshooting 6 Nov 4th, 02 08:14 PM
weird timing problem??? 68and69ss Troubleshooting 12 Apr 28th, 01 10:22 PM
