Starting problem - Team Camaro Tech
post #1 of 12 (permalink) Old Nov 29th, 06, 03:47 AM Thread Starter
Starting problem
I have a 2000 camaro base model. When you first turn the inigtion on in the morning you can hear that first initial fuel shot and then crank it over. Mine you hear a little thud noise but it does start. As the day goes on it gets harder to start. I have to crank it a couple of time or just hold the igintion until it does start. Seems like the fuel is not staying pressurized. I had the injectors cleaned and I replaced the fuel filter. Did not fix the problem. Any suggestions??
Jake
Jake1957 is offline
post #2 of 12 (permalink) Old Nov 29th, 06, 10:59 AM
madmax87's Avatar
Re: Starting problem
My friends 1997 SS basically did the same thing but ended up not starting at all. Ended up being the fuel pump. (Only 60K miles). I'm not sure on a 2000 but he cut a access hole in the rear trunk area and was able to replace the pump from inside the car. Was really not that bad if your careful. The thread on how to do it is on this site. I would probably get a fuel pressure meter and throw it on the rail and see what it reads 1st.
madmax87 is offline
post #3 of 12 (permalink) Old Nov 29th, 06, 11:39 AM
Todd
Sounds like a pump to me as well. They get worse when they are hot. Those pumps are a pain in the but if you don't have a lift.
Vegas69 is offline
post #4 of 12 (permalink) Old Nov 29th, 06, 12:05 PM Thread Starter
I just took a pressure reading of the pump. Should be 48 to 55. Actual reading under 44
Jake1957 is offline
post #5 of 12 (permalink) Old Nov 29th, 06, 12:16 PM
madmax87's Avatar
Maybe take a reading after driving the car awhile. See if it gets worse. Then you'll know for sure.
madmax87 is offline
post #6 of 12 (permalink) Old Nov 29th, 06, 08:07 PM Thread Starter
Reading after running it awhile was still around 44 psi
Jake1957 is offline
post #7 of 12 (permalink) Old Dec 1st, 06, 02:02 AM
madmax87's Avatar
Well I'd hate to say thats your problem. I would expect to see less pressure but I don't really know where the cutoff is for the car to run right. Hopefully someone will confirm this for you.
madmax87 is offline
post #8 of 12 (permalink) Old Dec 1st, 06, 06:26 PM
Gary
44 lbs is plenty of fuel... sounds like it is intermittant loss of fuel pressure. So keep the gauge on the car and check it when it is hard to start...
Gary 9t4Z
69,70,91,91,94
9T4Z is offline
post #9 of 12 (permalink) Old Feb 4th, 07, 04:48 AM Thread Starter
Gary 9t4z,
If I had a intermittant loss of fuel, what could be the cause? Thanks Jake
Jake1957 is offline
post #10 of 12 (permalink) Old Feb 5th, 07, 03:52 AM Thread Starter
Anyone with any ideas, please let me know. When I changed the pump the fuel pressure stayed the same at 44 to 45 psi.
Jake1957 is offline
post #11 of 12 (permalink) Old Feb 5th, 07, 04:28 AM
Injector power relay(s)?
PCM power relay?
All ground connections? As wire connections get warmer, they present a higher resistance to current flow, thus less voltage to the circuit being powered.
Just a thought.
post #12 of 12 (permalink) Old Feb 5th, 07, 05:32 PM
Gary
Originally Posted by Jake1957 View Post
Gary 9t4z,
so you replaced your fuel pump since your original post?
Intermittant loss of fuel pressure... bad connection at the relay which is located under the car above the axle. Check all connections... that is assuming that fuel pressure is your problem. You have to drive around with a fuel press. guage hooked up and see if it drops off. Usually fuel pumps will just work or quit... not usually half bad... all bad. Thats why you hear of people hammering on the gas tank with a hammer... jars a fuel pump back to life for a few more days or weeks. The problem is not low pressure... 44# is enough.
Gary 9t4Z
69,70,91,91,94
9T4Z is offline
starting problem zachleist Engine 1 Jun 27th, 06 04:07 PM
Starting Problem hgerrick Electrical & Wiring 6 Feb 8th, 05 07:14 PM
starting problem shrtrnd7 Troubleshooting 2 Apr 13th, 04 05:45 AM
LT1 hot starting problem Robert Higgins Troubleshooting 1 Mar 8th, 01 04:04 PM
Starting (Cranking) Problem Mark W. Winning Troubleshooting 6 Nov 13th, 00 03:51 AM
