starting engine after 7 months - Team Camaro Tech
post #1 of 13 (permalink) Old Dec 1st, 06, 05:54 PM Thread Starter
Paul
Hi TC, I need any suggestion for starting my '69 rs after sitting for 7 months. After a lenghty repair due to family commitments, i'm finally ready to give it a shot. I don't have a primer to get the engine all oiled up, but I was thinking of removing the coil wire to the distributor and crank the engine a few times. Do you recommend me doing this or should I just go for it and hopefully the engine starts? I just need to confirm. Thanks again in advance.
69rszee is offline
post #2 of 13 (permalink) Old Dec 1st, 06, 06:07 PM
Todd
Re: starting engine after 7 months
I would change the oil and filter and pull the coil wire and turn it over to prime the pump.
Vegas69 is offline
post #3 of 13 (permalink) Old Dec 1st, 06, 06:23 PM
Gary
Seven months seems like a long time when you miss your car. If put away properly you wouldn't be worried... but if it was just shut down then I have a couple of extra suggestions...
Remove the plugs and spray in wd40... oily and volitile enough to ignite fast. I agree to change the oil.... when you put in the new filter fill it up full before spinning it on. Priming the engine by spinning is good but adds gas.... so I'd only do that if I oiled up the cylinders first... if you are really ambitious you disconnect the fuel line.. and plug it... then spin the engine with the coil wire off.... then reconnect and fire it up. The bad gas in the bowl will be gone.
If you have a real rich idle afterward then you can expect the needle and seat to be gummy from old gas left in the carb... then go from there.
Good luck
Gary 9t4Z
69,70,91,91,94
9T4Z is offline
post #4 of 13 (permalink) Old Dec 1st, 06, 06:54 PM
I would not crank the motor over to try to get the oil moving. I would spray some oil in the cylinders, tho I'd use marvell mystery oil, not WD-40.
Then just crank her over and let her fire. You'll get the oil moving quickest with the motor running at a fast idle, much quicker than the starter motor would. Starting is the hardest thing on an engine, don't drag it out.
post #5 of 13 (permalink) Old Dec 2nd, 06, 10:06 AM
Bob
I have cars that sit a lot longer than that, And i've never had any issues with just fireing them up. Jim is right, just light it up quick and get the oil flowing. Shouldnt have any problems.
bob
Bgonz 69 is offline
post #6 of 13 (permalink) Old Dec 2nd, 06, 10:54 AM
Fred
Here's one for you guys! My Camaro was in the garage, un-started, for 3 and half years until 2003. (I was rebuilding my sailboat) It had half a tank of gas. I did the usual stuff but I pulled the plugs to crank it and build pressure. Once I got it I hooked up everything. Including the new batteries and high torque mini starter. I DIDN'T CHANGE THE FUEL. Guess what! Fired INSTANTLY and ran perfectly!
Then I had to wash the teak dust off of it.
128.79mph 1.428 60'
Fred Ficarra is offline
post #7 of 13 (permalink) Old Dec 2nd, 06, 03:08 PM Thread Starter
Paul
Thanks guys for the quick responses. I'm on my way to pick up some marvell mystery oil and hopefully i'll be able to work on the car tomorrow. I'll let you all know of the outcome. Thanks again. Great looking car Fred.
69rszee is offline
post #8 of 13 (permalink) Old Dec 2nd, 06, 03:19 PM
Fred
Thanks 69!
128.79mph 1.428 60'
post #9 of 13 (permalink) Old Dec 3rd, 06, 05:22 PM Thread Starter
Paul
Hi guys, it worked. All I added was the Marvell Mystery Oil and it fired right up. We'll not exactly, this might be another issue, but I was not getting fuel to the Carb. This is the second time I needed to prime the fuel line after my mechanical fuel pump by using my thumb and cranking the motor until gas flowed out. Is this an indication that my pump is going or is it something in the tank? Thanks again in getting my motor running - boy it sounds good.
69rszee is offline
post #10 of 13 (permalink) Old Dec 3rd, 06, 05:44 PM
JohnZ's Avatar
My cars have sat for 6-7 months every winter for 40+ years (in the garage), and all I do in the spring is fill the float bowl with a syringe through the bowl vent tube and they start instantly. I change the oil a day or two before I put them up for the winter, pump up the tires, and put a Battery Tender on them once a month during the winter for a day to keep the charge level up, and never start them during storage (unless I'm going to drive them at least ten miles, to get the oil good and hot).
JohnZ
CRG
JohnZ is offline
post #11 of 13 (permalink) Old Dec 3rd, 06, 06:47 PM
John, do you put any fuel stablizer in your tank before you store your car away for the winter months?
Camaro buds until the end!!!
Camaro Dave is offline
post #12 of 13 (permalink) Old Dec 10th, 06, 03:52 PM
JohnZ's Avatar
Nope, not necessary for garaged winter storage - I just fill the tank first to minimize the airspace in the tank where condensation can form. Today's gas is very stable up to a year or so, and the colder it is, the less it deteriorates.
JohnZ
CRG
JohnZ is offline
post #13 of 13 (permalink) Old Dec 10th, 06, 06:58 PM
Thanks, Good advice!
hi performer engines jdbr1 Engine 7 May 28th, 07 05:56 AM
What is this engine?? New67RS Engine 5 Mar 30th, 06 06:32 PM
WHY KEEP ENGINE RPMS under 7000rpm grumpyvette Performance 50 Oct 4th, 05 09:39 AM
77 Camaro needs engine, help! danhei Engine 18 Oct 18th, 03 02:46 PM
Starting engine after long term storage. Toby T. Engine 6 Apr 4th, 01 03:56 PM
