black wire in steering column harness - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 2nd, 06, 06:59 PM Thread Starter
Errol
on my 69 ,I have a black wire that is not plugged in....It is the last wire on the steering column haness,( the 2 piece harness)the harness hooks to the side of the column.the harness has about 12 wires. any help.
Flynn69 is offline
post #2 of 6 (permalink) Old Dec 2nd, 06, 07:36 PM
Re: black wire in steering column harness
horn
post #3 of 6 (permalink) Old Dec 2nd, 06, 07:56 PM Thread Starter
Errol
This is a problem I,ve had from 3 mos ago. I hook my battery up and the horn blows.Changed everything .Took the steering wheel apart . Check the rag joint,replaced the relay. so I left the horns unplugged. Last nite I put the neutral safty back in. worked great.Tonite i hooked the battery up and the relay ticking away. so I thought I disturbed something under the dash. I find this black wire hanging from day one.Just tucked it away. But If you say its the horn,then it is not grounded right. It has to be connected so the horns won,t go off. This is a long shot.......Could it bve that this wire has to go somewhere......................Any info would be great. Errol
Flynn69 is offline
post #4 of 6 (permalink) Old Dec 2nd, 06, 08:53 PM
Errol, the horn is an active low circuit. When the wire is grounded, the horn blows, when it is not grounded, the horn does not blow.
Also, I am not certain that the horn wire is the only black wire in the column, but I am certain the horn wire is black.
post #5 of 6 (permalink) Old Dec 3rd, 06, 01:03 PM Thread Starter
Errol
any body else know what the black wire is for that is at the end on the steering column harness plug. There is 12 wires on the plug.This wire is black and has a connector to fit in this plug.The book gives a not good enough answer. Thanks
Flynn69 is offline
post #6 of 6 (permalink) Old Dec 3rd, 06, 01:59 PM
The very last black wire and the one next to it (pink/black) are for the key warning buzzer wires. The next black wire is for the horn ground.
JIML82
JIML82 is offline
Steering Column Disassembly emdoller Brakes, Suspension & Steering 3 May 20th, 06 09:40 PM
'68 Tilt Steering Column: How much slop should there be? ggkeller Brakes, Suspension & Steering 2 Jun 28th, 05 07:59 PM
Wire cluster under steering column 69rag327 Electrical & Wiring 3 Mar 19th, 05 11:03 AM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 01:20 PM
engine wiring harness, extra wire? tdpole Electrical & Wiring 15 Jan 30th, 02 04:34 AM
