Have a tapping under load?? - Team Camaro Tech
post #1 of 39 (permalink) Old Dec 7th, 06, 02:20 PM Thread Starter
Steps
Newly rebuilt 350, top o bottom. fully balanced, bearings plasti gauged, everything "by the book."
We have been chasing this for a while
Replaced all the new rockers, balls, push rods, lifters and still there, remeasured the cam to check for signs of bad bedding in...all ok.
We did have 2 taps...found that early...with the higher lift cam, one of the rockers was just touching the tappet cover, we ground a little off the inside and thats gone....at the same time we ground a little off in the spot where a rocker could possibly touch.
The tapping is just like a loose rocker adjustment...
There is no pulling of studs or nuts backing off
There are no leaks on the manifolds
It is not in the water pump, pullieys, alternater or anything like that
There is no missing, power loose or a sparks jumping.
No pinging and plugs are txt book.
Oil pressure and temps are excellent.
It only taps when under light to full load on the road
It sounds (from inside the car) to be drivers side
Steptoe is offline
post #2 of 39 (permalink) Old Dec 7th, 06, 02:24 PM
Re: Have a tapping under load??
Fuel Pump Pushrod?
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #3 of 39 (permalink) Old Dec 7th, 06, 02:33 PM
Fred
OK, if it only does it under load then it's not your valve train. Hmmm, is this a test?
Not a incorrect/wrong bearing in your kit,,, you plastigauged it. Hmmm. Under Load,,,,,.
Are you positive it's not an exhaust leak?
128.79mph 1.428 60'
Fred Ficarra is offline
post #4 of 39 (permalink) Old Dec 7th, 06, 02:36 PM
Fred
Originally Posted by Mark C View Post
Fuel Pump Pushrod?
MARK! I was going to say that! But it's on the drivers side. Diagnosing a fuel pump broken return spring when I was a kid brings back 40 year old memories. It made me 'one of the guys' at the local hangout.
And that kind of noise should happen with no-load too.
128.79mph 1.428 60'
post #5 of 39 (permalink) Old Dec 7th, 06, 02:42 PM
Fred
Under load???? Are you sure it can't be made to knock by reving the engine in neutral? Piston touching head maybe???
128.79mph 1.428 60'
post #6 of 39 (permalink) Old Dec 7th, 06, 05:01 PM Thread Starter
Steps
No it is not fuel pump...it doesnt have a fuel pump, doesnt even have a petrol line or pertrol tank lol
Piston touching head, no...everything was dumied up for clearances before assembly ...without head gaskets
And will not do it in neutral and rev unless 1st starting in the morning, disappears after about 100 yrds.
Absolutly positive is not exhaust leak...2x new gaskets, running cast rams horns, checked flat surfaces, checked for leaks, retorqued more times than I can remember now
Summer is here, Xmas holidays, club runs, show season...
I had something similar, yrs ago on an engine, eventually stripped it right down and found a cracked piston!!! just hoping Dont have to strip down again...means not just replacing the pistion but rebalancing etc etc
Steptoe is offline
post #7 of 39 (permalink) Old Dec 7th, 06, 11:37 PM
Fred
Oh great! Now I'm going to lay awake all night thinking about it!
Don't fret about the balance. Just duplicate the old piston weight, if it comes to that.
Hmmm, maybe it's time for a leakdown test,,,,
128.79mph 1.428 60'
post #8 of 39 (permalink) Old Dec 8th, 06, 03:18 AM Thread Starter
Steps
Compressions are all good...Engine has now done about 500 miles, loaded it but havnt opened her full up thru the gears yet...its bedding in nice and the idle screw has had to be turned down a turn.
Compressions are good...radiator coolant clean and no HC. oil is good...been changed a couple times now...
I think I know its a piston and just dont want to admit it cause I have so much work on at the moment
Steptoe is offline
post #9 of 39 (permalink) Old Dec 8th, 06, 03:39 AM
If you have to replace a piston, the shop can rebalance the piston by itself to match the engine balance. They get the weight from the balance card listing.
You still have the balance card? All the weights of the components are listed.
And as Fred suggested, I'd either do a leakdown test or at least shove shop air into each cylinder and feel the oil fill for amount of blow-by on each cylinder.
post #10 of 39 (permalink) Old Dec 8th, 06, 09:39 AM
Fred
Cheer up. We had record winter ugly weather last month. There's still snow on the ground from LAST MONTH. And winter is two weeks away. Feel better?
128.79mph 1.428 60'
post #11 of 39 (permalink) Old Dec 9th, 06, 10:19 AM
Fred
I warned you! As I laid awake most of the night, it dawned on me. You're driving FROM THE WRONG SIDE OF THE ROAD. Your car is probably a right hand driver. Right? So the drivers side is the starboard side?
OK, still no fuel pump. But no matter what's wrong you've gotta pull off the drivers side exhaust manifold. DO THAT FIRST. Let everything else wait. Inspect the hell out of it. Look under every corner and bend for a small crack. You know, the kind that gets bigger when heated-up under load. If there's one, it should be evident by now.
Also, are you running a heat valve? That's the flapper valve on the exit of one of the exhaust manifolds. If so, it's worth a look. Good Luck.
More cheery news for you. That snow from two weeks ago is still here. Melting like crazy but there's still some virgin stuff, and it's raining again like crazy! Not even the birds can/will fly! Cheered up?
128.79mph 1.428 60'
post #12 of 39 (permalink) Old Dec 9th, 06, 11:13 AM Thread Starter
Steps
Thats a possiblity...cracked manifold...
Yep will crack test this week, thu its still a long shot.
There is something wrong with the weather, Summer here and we have had a hudge temp drop and out od season hail yesterday
Steptoe is offline
post #13 of 39 (permalink) Old Dec 9th, 06, 04:58 PM
Tapping? Like valve clatter? Timing?
TC # 349
zdld17 is offline
post #14 of 39 (permalink) Old Dec 10th, 06, 11:44 AM Thread Starter
Steps
Yes I do have the balance sheets...still have the ones from back in 86 rebuild
Exhust manifolds has no cracks
Did have a lifter type tap...1 was just touching the Al cover ..thats fixed..
Its hard to describe...a deep tapping or a tapping type of knock???
It is not the valve train... the new valve train been fully replaced...did find a faulty lifter...
Im coming back to a cracked piston,,,,someone drop the box of pistons someware between the factory and shelf here in NZ???
Steptoe is offline
post #15 of 39 (permalink) Old Dec 10th, 06, 03:54 PM
A cracked flywheel or bad torque converter will make a racket under a load.
skintback is offline
What makes a "clack clack clack" sound under load? davepl Camaro Tech 25 Apr 7th, 09 05:16 PM
Tire load Weight? Joe 69 Wheels & Tires 6 Jul 22nd, 06 08:26 PM
Tapping and Knocking.... lineberger Engine 7 Jun 28th, 06 06:12 AM
tapping secgenmaro81 Engine 4 Mar 14th, 06 12:56 PM
Post launch tapping Larry's 69 Engine 9 Jul 30th, 05 05:59 AM
