foot to the firewall.....clutch starts to engage if I even breath!!! - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 19th, 06, 02:35 PM Thread Starter
I always thought that your clutch was going out when you barely press on the pedal and it starts to slip. Mine is just the opposite. I have to mash it to the floor and if I even flintch, it starts to engage. Are the pressure plate fingers shot??? What could it be??? Thanks!!!!
dubs68camaro is offline
post #2 of 4 (permalink) Old Dec 19th, 06, 03:46 PM
Kevin
SixtyAte's Avatar
Re: foot to the firewall.....clutch starts to engage if I even breath!!!
You may have adjusted it wrong or used wrong parts. You should have about one inch free play. Get under and back off on the adjuster nut until the rod almost falls out of the fork then tighten it a little more and try it.
Kev
SixtyAte is offline
post #3 of 4 (permalink) Old Dec 24th, 06, 03:42 PM
Send a message via MSN to kausboy
As your clutch wears your free play decreases. As SixtyAte said, adjust so you have about an inch of freeplay when the pedal is up. Often times when a pressure plate wears out they fail to disengage properly.
kausboy is offline
post #4 of 4 (permalink) Old Dec 25th, 06, 04:15 PM Thread Starter
Thanks guys!!!! Already got it fixed. Bought the truck thinking I was going to have to replace the clutch and it was just linkage REALLY out of adjustment. Thanks again!!!!
Dub
Clutch setup/Adjustment paulm Transmission & Driveline 8 Sep 29th, 06 12:58 PM
Clutch fork hitting firewall 19673274sp Transmission & Driveline 5 Feb 8th, 05 10:47 AM
Clutch rod firewall boot CarlC Transmission & Driveline 6 Mar 26th, 04 12:36 PM
Clutch problems Camaro_Kyle Transmission & Driveline 5 Apr 8th, 03 04:37 AM
Firewall Boot for Clutch Rod Wing nut Tech 2001 2 Oct 27th, 01 12:10 PM
