Broken tap - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 27th, 06, 02:44 PM Thread Starter
Broken tap
Does anyone have a solution to remove a broken tap. I was cleaning out the threads in an exhaust manifold and it came loose frm the vise, fell on the floor and of course landed on the tap breaking it off. It's not super tight as I was just cleaning the threads using oil and tightening and loosening but it is recessed about 1/4" inside the manifold.
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is offline
post #2 of 5 (permalink) Old Dec 27th, 06, 03:18 PM
Harry
dawg's Avatar
Re: Broken tap
depending on the size needle nose pliers .
or get the tool to remove broken taps.
looks like 2 prongs that fit into the flutes of the broken piece.
btw in the future dont use taps to clean threads.
use thread chasers.
at least thats what the pros use
434 stroker
US Navy retired
dawg is offline
post #3 of 5 (permalink) Old Dec 27th, 06, 03:24 PM
Kevin
SixtyAte's Avatar
Re: Broken tap
You could try to use a prick punch, tapping easily round and round counter clockwise seeing its just below the surface. After a few turns you could grab it with vice grips. Worst case scenario is to drill the center of the bolt using a carbide bit, then use an easy-out to rotate it out.
Kev
SixtyAte is offline
post #4 of 5 (permalink) Old Dec 27th, 06, 04:03 PM Thread Starter
Re: Broken tap
Thanks guys, tried the punch,to far in. I'll try the removal tool.
1969 Z28
1969 Firebird 400
nashcar is offline
post #5 of 5 (permalink) Old Dec 27th, 06, 04:27 PM
Re: Broken tap
Kev
Just like Kev said. Drill it and use an easy-out to remove the broken tap. Anything else used, might damage the threads.
Camaro buds until the end!!!
Camaro Dave is offline
Heater tap location lazyone Heating & Cooling 6 May 11th, 06 01:25 AM
Broken Tranny Mount SSmoked24 Transmission & Driveline 1 Dec 22nd, 05 04:29 PM
Broken Transmission Mount? SSmoked24 Camaro Tech 3 Dec 22nd, 05 03:36 PM
throwout bearing/ fork broken jks67SS396 Transmission & Driveline 4 Oct 19th, 03 08:37 PM
