Horrible squeel when turning left - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 31st, 06, 09:27 PM Thread Starter
I went for a short cruise this afternoon. After driving about 5 to 6 miles I stopped at a 4 way stop. When I pulled away ,turning left, onto a side street a loud squeel came from under the hood. I continued on straight once I was in 3rd gear I put the trans in neutral and blipped the throttle. The noise went away. The next time I turned left, after coming to a stop, the squeel came back again, but went away as soon as I was driving in a straight line again.
When i got home I stopped in the driveway and waited for the garage door to open. When I proceeded to drive up into the garage, going straight, the squeel came back again. ????
I checked the P/S fluid level. It was about 1/4 inch over the hot mark on the little stick in the cap. The belts are not new but only have about 600 miles on them.
Ideas please..... new pump time or just a new belt?
Thanks,
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #2 of 5 (permalink) Old Dec 31st, 06, 11:50 PM
Fred
Re: Horrible squeel when turning left
Fred, you can't check your belts by looking, you have to test the tension with a thumb press. (engine OFF of course) I'm sure your belt needs tightening. Happy New Year!
128.79mph 1.428 60'
Fred Ficarra is offline
post #3 of 5 (permalink) Old Jan 1st, 07, 04:22 AM
Rick
Also, if they did squeal put a new belt on and recheck after you go for a drive. In my case, once the belt slipped it was never quiet again even when adjusted correctly. I also went with Dayco topcog belts which helped.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #4 of 5 (permalink) Old Jan 1st, 07, 06:48 AM
Loose belt, as stated, is most likely culprit.
However, also check to make sure pulleys are correct and aligned properly. These old cars often have the engines in and out, or swapped from SB to BB or vice versa, so with all the changes that typically occur, sometimes the wrong pulleys and brackets are jury-rigged into position. You can check pulley alignment just by standing off to side of car and visually looking. Sometimes I use a long straight-edge metal ruler (laid against sides of pulleys) to confirm that alignment is kosher....
Dave F. in Rhode Island
Chevy-SS is offline
post #5 of 5 (permalink) Old Jan 1st, 07, 07:55 PM Thread Starter
New belts did the trick. $20.00 and 20 minutes!
Thanks guys!
__________
Outer Left Tail Light Won't Light Up SFCamaro Electrical & Wiring 2 Oct 6th, 06 12:05 PM
Scraping noise from left front MCGOO Brakes, Suspension & Steering 7 Jun 2nd, 06 06:00 PM
69 rear turning lights & headlights? Frost Green 69 Electrical & Wiring 1 Oct 10th, 05 06:55 AM
Left turn vibration? stevo camaro Brakes, Suspension & Steering 3 Jul 16th, 04 07:42 PM
