95 camaro starting - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 2nd, 07, 12:53 PM Thread Starter
figure8n
Question 95 camaro starting
Your gonna love this one!!!
Recent rebuild everything shiny new. starts fine for a few days then progressively starts to click click, then wil not start. Investgated a bit and bought some shims. Installed the 40 and seemed to fix the prob. Back to same prob again. Incidently, this issue was present before the rebuild though it would start after a few very diligent tries.
figure8n is offline
post #2 of 2 (permalink) Old Jan 2nd, 07, 01:41 PM
Kevin
SixtyAte's Avatar
Re: 95 camaro starting
It seems that you are talking about the starter. If you get click,click,click it means you have low voltage (weak battery) or bad connections . Check the power and ground connections on the battery and engine, clean them and put them back on. Charge the battery and see if it starts. You could have a weak or bad battery along with charging system that is not up to par....
Kev
SixtyAte is offline
DIY Network 1968 Camaro Restoration Show Brentmc Bench Racing 2 Mar 14th, 06 09:41 AM
Considering selling my Camaro Hrod382 Bench Racing 20 Feb 1st, 06 05:15 PM
2005 SuperCar Reunion & Outdoor MuscleCar Show Sept. 2 & 3 CamarosRus Team Camaro Cruiz-Ins 19 Sep 7th, 05 06:53 PM
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 07:37 AM
94 Camaro not starting!!! GlimTwin73 Troubleshooting 4 May 16th, 02 03:22 AM
