Turbo 350 Troubles - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 2nd, 07, 10:10 PM Thread Starter
Robby
Exclamation Turbo 350 Troubles
Hello, I am having a bit of trouble with my tranny. It seems fine until it gets warm, when its warm it doesn't want to engage into reverse, I really have to give it some gas and even then it barely moves. Also if I am driving along in drive it will surge in and out of 3rd gear. I recently swapped the motor and had no trouble before. I have dropped the pan and replaced the filter, the old one was filled with metal shavings which I am concerned about. The only thing different on the new motor is I put headers on it. I thought it may be overheating so I put some heat sheilds on the tranny lines. The lower line had a small amount of fluid drain out when I removed it, but the top one was dry. I am thinking I may have a bad pump and am leaning toward putting a th-400 in it and forget about the current tranny. Any input will be helpful. Thanks
arp211 is offline
post #2 of 3 (permalink) Old Jan 4th, 07, 12:02 PM
Steps
Re: Turbo 350 Troubles
Replace otr rebuild it
Steptoe is offline
post #3 of 3 (permalink) Old Jan 9th, 07, 01:45 PM
Sounds like the direct clutch is toast - a common problem. A rebuild is the only way to fix it.
dnult is offline
Replacing the Cross Member on a Turbo 350 Hank's 68 Transmission & Driveline 4 Aug 14th, 06 10:06 AM
turbo 350 modifcations for the track tips tricks? Quick_68 Transmission & Driveline 2 Jul 31st, 06 10:13 AM
filling turbo 350 SC42 Transmission & Driveline 2 Jul 12th, 06 01:55 PM
turbo 350 build questions 69rsinms Transmission & Driveline 7 Apr 6th, 06 12:14 AM
muncie to turbo 350 paperman Transmission & Driveline 1 Mar 16th, 04 10:29 AM
