Turn Signal Issues - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 9th, 07, 07:48 AM Thread Starter
Turn Signal Issues
When I use my right turn signal on my 69 x44 it flashes quickly.
I can turn it off after the turn, but as I am driving it will light on the dash again. Not sure if it is lighting outside the car .
Is this a problem that anyone has had in the past?
The Lights are flashing correctly on the outside of the car...........When it is stationary.
As I drive the right flasher indicator light will come on and get stronger and dimmer without me activating the right turn signal.
The bulbs are working just fine.
I would love to get out and check to see if the outside flashers are lit but this doesnt happen on a reguler schedule and only when the car is moving.
Any ideas?
Michael 1969 X44 is offline
post #2 of 6 (permalink) Old Jan 9th, 07, 08:19 AM
Kevin
SixtyAte's Avatar
Re: Turn Signal Issues
Change the flasher...
Kev
SixtyAte is offline
post #3 of 6 (permalink) Old Jan 9th, 07, 09:07 AM
parkbrau's Avatar
If your not sure if its not lighting outside the car, then how do you know it is not working ? You said it not me...
Change the flasher (cheap), and give all your light sockets a good cleaning. And have someone stand out side the car and do an ops check on all your lights. You never know...you may have other lighting issues.
parkbrau is offline
post #4 of 6 (permalink) Old Jan 9th, 07, 10:51 AM
Send a message via MSN to kausboy
Also, check your grounds. Sometimes a bad bulb can cause that too. Have you had your guage cluster out? There is a ground there that caused me some similar problems on my 68.
kausboy is offline
post #5 of 6 (permalink) Old Jan 21st, 07, 05:11 PM
I'm with kausboy. Electrical oddities are most often bad grounds..........
Dave F. in Rhode Island
Chevy-SS is offline
post #6 of 6 (permalink) Old Jan 21st, 07, 05:59 PM
yup its a ground... either under dash or maybe at rad. supp. Make sure the bracket is behind headlight and wiper switch.(often discarded or hanging)
dragracinrs is offline
Car off, turn signal on-and blinking fast BW67 Electrical & Wiring 6 Oct 26th, 05 07:23 PM
right turn signal shows arrow, but wont flash? 72maroFF Electrical & Wiring 9 Oct 14th, 05 06:02 AM
Turn Signal won't cancel ChevyThunder Electrical & Wiring 1 Oct 11th, 05 05:47 PM
Turn signal lizzietish Electrical & Wiring 6 Feb 1st, 05 06:01 PM
light switch and turn signal roho29 Electrical & Wiring 1 Mar 30th, 04 06:15 AM
