Need Engine help PLZ - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 17th, 07, 02:53 PM Thread Starter
Doug
My 94 camaro v6 is bucking shuttering bad when i give it gas while in park and in gear. I just did a tune up in august plugs wires fuel air filters trans fluid is good oil is good spark wires look good took off air filter not the problem put fuel injector cleaner in still doing it
The CAR is a 1994 CAMARO with 28000 miles on it yes (TWINTY THOUSAND) V6 oil changes ever 2 months all orginal but kn air filter and Dua exhaust from cat back normal mait item whelels brack ext .
druzzil is offline
post #2 of 6 (permalink) Old Jan 19th, 07, 10:56 AM
madmax87's Avatar
Re: Need Engine help PLZ
Was the car running good after the tune up and then started running bad? If so, I would check and see if any of the sensors came unplugged, especially on the air intake.
madmax87 is offline
post #3 of 6 (permalink) Old Jan 19th, 07, 11:34 PM
check all the plug wires. with only 6 cylinder, if you get one that isn't firing, it will make a hell of a difference in how it runs.
of course, a coil could have gone bad, as well, which would take out 2 cylinders, and make it run really bad. if you can track down which cylinders aren't firing, and if you have 2 cylinders that use the same coil that aren't firing, then replace that coil.
you don't plan sincerity.
novaderrik is offline
post #4 of 6 (permalink) Old Jan 20th, 07, 06:54 AM
Yeah, I'm with novaderrik. I think it's an ignition issue. Here's an easy way to check:
Start the engine and rev it up (you may need a buddy in the car), get it revving until you notice the skipping. Now, as it's skipping (shuddering) pull off one plug wire at a time. They make a special tool to do this so you can avoid getting shocked. Alternatively, you can use the sharp end of a test light and pierce the shock boot to short out the wire.
What you're looking for is: difference (or no difference) in engine sound as you disconnect (or short) the plug wire. If you disconnect a plug wire and the engine is running much rougher, then you know that cylinder is working. If you disconnect a plug wire and there is NO difference in engine sound, then that cylinder is NOT working.
If you find a cylinder that's not working, take off the plug wire, insert an old spark plug into the boot and lay the plug against the engine metal, then start engine and see if you have spark.
This will give you an idea of where to start looking for the problem.
Dave F. in Rhode Island
Chevy-SS is offline
post #5 of 6 (permalink) Old Jan 20th, 07, 02:11 PM
mike
could also be a vacuum leak over a specific cyl...but, probably ignition...do the plug wire thing to find the dead cyl, and check the plug on that cyl... if its crapped up, change all the plugs, but if not, look for a vac leak..i`ve seen alot of this where i did a tuneup, and 8-12 mos later, a plug is fouled...i noticed it every time they reformulated the fuel in my area...first mtbe, then ethanol...the plug would have a white powder on it,,,possibly from o2 sensor used to one formulation, and then changing...
kustomwerker is offline
post #6 of 6 (permalink) Old Feb 16th, 07, 06:07 PM
bill
hhmmmm you mentioned a k&m air filter? when did you install it. and also did you put oil in it as most use oil? why i say this is cause those filters you put oil in them and to much oil goes into the mass air flow sensor and they go crazy and gives bad readings to the computer. take the mass sensor out and clean it out with carb cleaner and put it back should run fine take for 5 mile drive since computer needs to relearn.
jaguareats is offline
Learning from revamping blower engine Tokyo Torquer Performance 11 Jan 24th, 07 12:44 PM
Engine Storage Stand That Allows Tranny Too mark67ss Engine 4 Dec 22nd, 05 06:24 PM
My 502 is driving me mad !! Engine Gurus', Please Help Me. paul1969 Performance 25 Dec 4th, 05 09:55 PM
1991 Camaro Engine Swap (88 IROC engine) Racing_Master Engine 7 Oct 20th, 05 03:22 AM
New Engine Break-IN Procedure (GM crate motor) sr71bb Engine 12 Dec 19th, 00 08:35 AM
