brakes locked up, seats dont fit....ahhhh - Team Camaro Tech
post #1 of 10 (permalink) Old Jan 20th, 07, 06:39 AM Thread Starter
so in the last 3 weeks, i have lowered the car and had the 4 point put in with the subframe connectors as well as the new seats. I was stoked. I had been driving the car sitting on the stock seat with springs going into my A$$.
Here are the problems: When we measured for the 4-point, we used the stock seats (wich i hadnt bolted in all the way), with the stock set up, the bar is more than 6 inches from my head, when we went to put the new seats in, we realized that they sat much higer than the stock hence putting my head 1/2 in from the roof and too close to the bar. Also, since the seats were never bolted in previously, we never realized that the driver side floor pan (which someone replaced previous to me owning the car), is uneven and we had to shim one side by and inch. So now i have to figer out if i can lower the seats at all (and we fabbed the seat mounts so we cant go any lower there) or i have to buy new ones. Also have to figure out if i should replace the driver side floor. OR, if i replace the driver side floor, if that will fix everything.
So, i then drive the car home from inglewood to the valley (for you out of staters, that is not fun on a friday afternoon at 4pm) and wow, what a difference with the subframe connecters tied into the 4 point....get all the way home and my girlfriend calls me from the mall with a dead battery. So i drive over in the camaro with a pal following me (he is building his 70 c10 truck which he is in and we talk a lot of smack), get over to the girlfriend, jump her mustang (i save the wisecrack about how a camaro came to the aid of a mustang), we depart and as i exit the mall, i realize that my rear brakes are stuck on.......have to pull back into the mall and get towed back. BUZZKILL!
THe parking brake is not on......so what the hell is this? It is not the rearend or tranny that i can tell, but the rear brakes are stuck on........any thoughts?
any thoughts on the seat issue... i will post pics later today....
AHHHHH thought i was so much closer.......damn!
thanks, feel better now.
oh yeah, 68 camaro with drums in the corners
D
s4dustin is offline
post #2 of 10 (permalink) Old Jan 20th, 07, 07:00 AM
Kevin
SixtyAte's Avatar
Re: brakes locked up, seats dont fit....ahhhh
I would say the rear shoes are too far out and after rubbing, they heated up and are stuck to the drums. When it cools down you should have been able to roll/drive the car a short distance. Back off on the rear shoes using the star adjuster and it should be fine. Check the shoes for heat cracks and replace them if needed.
Kev
SixtyAte is offline
post #3 of 10 (permalink) Old Jan 20th, 07, 07:01 AM Thread Starter
why would this have happened? and what can i do to minimize the risk in the future. I should have my new brakes in 3 months.....but i still want to drive the car
s4dustin is offline
post #4 of 10 (permalink) Old Jan 20th, 07, 11:50 AM
Kevin
SixtyAte's Avatar
If the wheel cylinders leaked fluid on the shoes it would cause this so I advise checking that also. A few things like adjusting the brakes too tight, driving with the emergency brake on etc. Have you checked under the car to see if there is slack in the emergency brake cables? If not, adjust that too.
Kev
SixtyAte is offline
post #5 of 10 (permalink) Old Jan 20th, 07, 12:05 PM Thread Starter
i checked the slack and it was fine. i am going to put it on the stands and pull the brakes apart later today.....thanks for the help
s4dustin is offline
post #6 of 10 (permalink) Old Jan 20th, 07, 12:43 PM
I'll presume these are rear drum brakes. Be sure the shoes are on correctly. There should be one long and one short shoe. I think the long shoe faces forward and the short faces rearward. I could be wrong though.
I doubt you have disc brakes, but I'll offer this anyway. It's not uncommon for the caliper hose to separate internally. The flapping rubber inside the hose can act like a check valve allowing fluid to enter but not escape the caliper piston. If a quick bleed releases the caliper then the hose is suspect.
dnult is offline
post #7 of 10 (permalink) Old Jan 20th, 07, 02:16 PM
mike
could be broken hardware, or leaky axle seal too...this problem is often contributed to shoe contamination, especially if the brakes havent been apart, then all of a sudden screwing up...look at the backing plates for oily residue, and when drums are off, pull back dust boots on whl cyls to see if they`re leaking...
kustomwerker is offline
post #8 of 10 (permalink) Old Jan 21st, 07, 07:12 AM Thread Starter
the hardware for the e-brake was bent to SH+t. almost in 2 pieces. i will get a spring kit and put it all back together. I should have my new discs in the next 2-3 months so.......
s4dustin is offline
post #9 of 10 (permalink) Old Jan 22nd, 07, 01:06 AM
short brake shoe goes on the from and the larger is the rear
you might also want to check and see that the cable slides freely inside the jacket or whatever, outer tubing, i dont know what to call it
my friends froze up when the parking brake was applied and stuck there
400bird is offline
post #10 of 10 (permalink) Old Jan 23rd, 07, 11:20 AM
Originally Posted by 400bird View Post
short brake shoe goes on the front and the larger is the rear
Thanks Bird.
dnult is offline
Spongy brake pedal, possible glazing of front brakes? cody Brakes, Suspension & Steering 14 Dec 6th, 06 11:19 PM
Comments on "Direct Fit Brakes, INC" sweeks68Camaro Brakes, Suspension & Steering 1 Mar 26th, 06 10:00 AM
moser with bear brakes do fit awesometool Brakes, Suspension & Steering 7 Mar 21st, 06 04:16 PM
JimM's brakes JimM Brakes, Suspension & Steering 41 Mar 8th, 06 05:39 PM
Will 70 steering and brakes fit a 67? curtis26 Brakes, Suspension & Steering 4 Feb 15th, 06 05:26 AM
