Bad connection? - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 21st, 07, 07:36 AM Thread Starter
Ed
Angry Bad connection?
I have a 93 camaro 3.4, I replaced the starter and the neg battery cable, It started right away, I started to drive it sounded alot louder then before, maybe I didnt tighten the y pipe tight enough or something else is wrong in the exhaust, it gets worse I am driving and it acts like it wants to stahl, this is at night it stops and then acts fine I stop for a while and then drive it again all of a sudden my lights go out the car just shuts off and I am clueless as to why, I pull in a parking lot open the hood and check the battery caonnections and they are fine and it starts up I drove it home and here we are, I am in need of help trying to under stand this,also the battery guage kept going down and then back to where it should be, Alternator maybe but it was working fine untill I changed the starter.
Thanks Ed
suldevan93 is offline
post #2 of 2 (permalink) Old Jan 21st, 07, 01:39 PM
mike
Re: Bad connection?
the big lug on the starter is loose, and you are getting an intermittant connection...as for the loud exhaust, try tightening the y pipe, and if still loud, change the gaskets from the manifold to the ypipe
kustomwerker is offline
Steering Box question- bad bearings? faninc Brakes, Suspension & Steering 3 Jul 9th, 06 02:03 PM
Bad window switch or bad motor Meanchicken Electrical & Wiring 2 Oct 3rd, 05 05:41 AM
Things are BAD BAD BAD rich pern Bench Racing 1 Aug 30th, 05 10:04 PM
torque converter bad? topdown69 Transmission & Driveline 2 Jun 28th, 05 11:30 AM
Even The Top Of The Line Has Its Bad Days bigdawginva Electrical & Wiring 0 Apr 21st, 05 05:19 PM
