1989 Camaro Dies In Low Rpm's - Team Camaro Tech
post #1 of 11 (permalink) Old Jan 25th, 07, 08:47 PM Thread Starter
WELL I HAVE A PROBLEM AND IM ABOUT TO GIVE UP ON IT WELL MY 1989 CAMARO RS TBI 5.0 TURNS OFF OR DIES ON ME WHEN IAM GOIN IN LOW RPM'S IT ALSO SOMETIMES DIES ON ME WHEN I AM ON A LIGHT OR STOP SIGN IT SEEMS TO ACCELERATE ITS SELF SOME TIMES TOO I DONT KNOW WHAT IT CAN BE IT ALSO SEEMS TO CHUG OR SURGE WHEN I HOLD THE RPM'S IN 1000-1500 IT SEEMS LIKE ITS CHOKING OR SOMETHING I HAVE NO IDEA WHAT IT CAN BE IF ANYBODY KNOWS CAN U PLEASE HELP ME THANKS I WILL APPRECIATE IT
topete13 is offline
post #2 of 11 (permalink) Old Jan 25th, 07, 09:21 PM
john
wagonman's Avatar
Re: 1989 Camaro Dies In Low Rpm's
sound like its dumping fuel.
wagonman is offline
post #3 of 11 (permalink) Old Jan 26th, 07, 04:27 PM Thread Starter
what do u mean by its dumpin fuel like its leaking or something do u know what i can do to fix it
topete13 is offline
post #4 of 11 (permalink) Old Jan 27th, 07, 06:56 AM
mike
u need to get it scanned to see what the computer is seeing...could be a bad temp sensor or something...
kustomwerker is offline
post #5 of 11 (permalink) Old Jan 29th, 07, 03:42 PM
J.J.
Send a message via AIM to jj69z28
sounds more like a bad fuel pump or clogged fuel filter to me.
Rally Green 1969 Camaro Z/28
jj69z28 is offline
post #6 of 11 (permalink) Old Jan 29th, 07, 03:54 PM
mike
usually a bad filter or weak pump will show up at higher rpm or under heavier load as the car is using more fuel...another thing it could be is the iac motor...really need to get it scanned or jump out the aldl connector to get the codes...but i might be of more assistance if you got the codes..
post #7 of 11 (permalink) Old Feb 20th, 07, 06:11 AM
Josh
i also have an 89 camaro rs tbi 5.0 and i have been having the same problems that you have described. if you find out what it is and how to fix it please let me know.
that1sk8rkid is offline
post #8 of 11 (permalink) Old Feb 20th, 07, 06:42 AM
Mitch
Lost in the 60's's Avatar
The computer controlled engines need a very good ground circuit too. One simple thing you can do is follow all the wiring from the TBI injectors and make sure none of the wires is rubbed bare. Also pull all connectors apart and look for corrosion or dirt....they need to be clean, tight and a little dielectric grease in them guards against moisture. Do the same for the wires connecting to the oxygen sensor and coolant temp sensor. One member stated his coolant sensor was leaking just enough coolant under pressure to force it up the wire harness to a connector and caused a short. Make sure the ground wires from the engine to body and body to battery are free of rust and corrosion as well. All the electrical connections are extremely important on these cars and can cause all kinds of trouble. If it still acts up after all that, then I would suggest clearing all the existing codes at the aldl connector and drive for a short time to get new codes stored. You will then have a good record of immediate codes to have read and determine the problem. It could be a faulty TBI injector, oxygen sensor, coolant temp sensor, etc.
Good Luck......
...38 Chev coupe, street rod
...54 Chev 210 coupe
...62 Impala SS, driver/project
...67 Camaro, ss/rs LA built driver/project
...66 Chevelle SS, Atlanta built 138 driver/project
...69 C10, cab and clip may end up on the '89 rollback
...70 Chevelle SS, Canadian documented Z25 project
Lost in the 60's is offline
post #9 of 11 (permalink) Old Feb 20th, 07, 02:46 PM
mike
also tap on the map sensor with the car running...see if theres any change in idle...if there is, change the map sensor...
sometimes you`re the windshield and sometimes you`re the bug...
post #10 of 11 (permalink) Old Feb 20th, 07, 02:49 PM
ZZ_430's Avatar
Make sure both injectors are spraying fuel.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #11 of 11 (permalink) Old Feb 20th, 07, 02:52 PM
hmmm, did I see this one before? Is it still live?
#1 cause of a flaky or irregular idle on an EFI car is a dirty or bad Idle Air Control motor.
Look for a 1" diameter by 1" long cylinder, 2 ears with screws screwing it to the throttle body somewhere, has an electrical connector.
Take it off, and clean it good with carb cleaner and a toothbrush. With luck, problem will go away and never come back. If it goes away for a while then comes back, get a new one. If it don't go away, keep looking.
91 camaro dies beastlycamaroZ28 Camaro Tech 1 Jun 10th, 05 09:55 PM
91 Camaro dies when put into gear. beastlycamaroZ28 Troubleshooting 1 Jun 9th, 05 03:42 PM
95 camaro 3.8 turns over but dies after idle!!! jaydog50 Troubleshooting 1 Mar 29th, 05 09:50 PM
95 camaro dies Al-cam Troubleshooting 2 Apr 15th, 01 09:38 AM
1995 Camaro dies occasionally Jennette Troubleshooting 10 Jan 27th, 00 12:27 PM
