Problems...yet again - Team Camaro Tech
post #1 of 9 (permalink) Old Jan 30th, 07, 06:29 AM Thread Starter
Kyle
Send a message via AIM to MrCow350
My distributor (it sounds like it comes from the distributor) is making a constant low clicking noise. Also in the morning when i start up my car, if i give it any gas it either cuts off or revs up....and in the process of reving up i hear a loud pop of some sort under the hood. I drive a 78 camaro, new 350 crate engine and such. Sometime in the recent past i had my carb rebuilt because some sort of internal combustion was happenin inside my carb and the whole inside was burnt up....float and all??? thanks for the help.
MrCow350 is offline
post #2 of 9 (permalink) Old Jan 30th, 07, 06:58 AM
Harry
dawg's Avatar
Re: Problems...yet again
sounds like a broken spring on the weights.
434 stroker
US Navy retired
dawg is offline
post #3 of 9 (permalink) Old Jan 30th, 07, 01:33 PM
Russell
Send a message via AIM to capt68 Send a message via Yahoo to capt68
Let's narrow your problem down a bit.
1) What type and size carb are you running?
2) Does the engine idle smoothly or does it vary/surge at idle?
3) Could the loud pop be the carb backfiring?
4) Is the motor running any hotter than before this problem started?
5) What type of distributor; points or HEI?
6) How many miles do you have on this motor?
7) How was the car running prior to the carb rebuild?
8) Have you checked the timing?
9) Could the clicking noise be caused by plug wire crossfire or a small crack in the distributor cap? How long has it been since you replaced the wires, cap and rotor?
Like Dawgs said, it could be a broken spring attached to the weights in the distributor. Your discription obviously leads to either carb trouble (still) or some type of ignition issue. If you have a friend with some extra parts, try another carb and/or distributor. That would be the easiest way to find the trouble. If the car was running well before the carb rebuild and runs like crap after, the problem may still be related to the carb. Then again, ignition problems could have led to your carb problems in the first place. If the timing is off, it could cause a backfire in the carb.
Confused?????? It's a simple process of elimination.
Russell
Russell
capt68 is offline
post #4 of 9 (permalink) Old Jan 30th, 07, 06:38 PM Thread Starter
Kyle
I think my carb is a rochester, and it's a 2 barrel. It idle's fine to me. No probs. The pop sounds like it comes from at the carb or distributor, i will look into that. It's a new 350 and has less than 2500 miles. Car was still running ****ty before the rebuild, i got the carb like a year ago brand new. I dont know how to check timing and the wires are new.
MrCow350 is offline
post #5 of 9 (permalink) Old Jan 30th, 07, 07:41 PM
mike
maybe its got a chocolate cam...improper breakin procedures can cause a wiped cam lobe that will really show up on a cold engine...does the car have a skip???maybe not as smooth as it should be???even if smooth, the lobe could be drastically smaller than the rest...just throwin it out there...
kustomwerker is offline
post #6 of 9 (permalink) Old Jan 31st, 07, 02:59 PM
If the distributor cap is not on straight it will make a ticking sound. I've seen it happen on 1st gen Camaros with a big-body HEI distributor. The cap get's smashed against the firewall and doesn't set on straight. If you look at the inside of the cap, you may see a grove carved out where the rotor tab mills away the inside of the cap if that is the issue.
dnult is offline
post #7 of 9 (permalink) Old Jan 31st, 07, 06:16 PM
mike
the burnt up carb is whats makin me think of a bad exhaust lobe on the cam...the first post said the whole carb was burnt up inside...something about loud popping when u revv it up...did the motor run good and th n just start this problem???
post #8 of 9 (permalink) Old Feb 1st, 07, 05:14 PM
george
Noise under the cap?A bad plug wire will cause spark scatter and sound like a snapping type noise under the cap.The spark may be carbon tracking to another cyl and causing the backfire under the carb.Lift the cap and look for what looks like a #2 lead pencil line tracking away from a terminal.Hope this helps you.
fatblock is offline
post #9 of 9 (permalink) Old Feb 4th, 07, 06:33 AM Thread Starter
Kyle
I will put all this to use, i know nothing about cars but i will getit checked out, thx.
MrCow350 is offline
Fan Problems I_love_my_Camaro Electrical & Wiring 4 Nov 29th, 06 07:00 PM
Multiple problems. Ticking ( probably lifter ) and screeching noise with low battery. elikhi Troubleshooting 9 Sep 18th, 06 05:25 PM
Traction and Misc. launch problems Dbl0No Performance 6 Oct 27th, 05 06:17 PM
Goodmark Quarter Panel Problems!!!! Liveinaz Body Shop 7 Jun 28th, 05 08:10 PM
MSD PROBLEMS RAY NORLIN Troubleshooting 3 Oct 9th, 00 02:40 PM
