Rotating noise in front right wheel - Team Camaro Tech
post #1 of 10 (permalink) Old Jan 30th, 07, 08:21 PM Thread Starter
chucky
A noise comes from my front right wheel when im at a certen speed. As i take off i dont hear it but when i get to about 30 mph it comes. Its not a constent noise its like a rotating noise. almost like a rock in a tin can. If u know what this might be please let me know. thank you.
chuckster2210 is offline
post #2 of 10 (permalink) Old Jan 30th, 07, 08:26 PM
Re: Rotating noise in front right wheel
We're going to need some details... what kind of car? disc brakes? drum brakes? wheel type? hub caps? etc.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #3 of 10 (permalink) Old Jan 30th, 07, 08:56 PM
I'd for sure pull the hubs off and check the bearings.
I'd do it right away, too.
post #4 of 10 (permalink) Old Jan 31st, 07, 08:17 AM
Yeah, as stated, check bearings. Better yet, just put a floor jack under the lower a-arm and jack up that wheel, then rotate by hand and listen. Check runout too, does it appear to be wobbling? Check tire for foreign objects, like piece of metal or bolt/nail. I would definitely pull the wheel and look at spindle/bearings/races etc. It's real easy to take wheel off.
If mechanicals all look good and there's no object in tire, then look at the tire itself. Is it perfectly normal-appearing, or is it scalloped or badly worn? I have seen worn tires cause noises that I SWORE were mechanical problems. I (and other mechanics) have been totally surprised by the noises that come from bad tires, so keep that in mind as you search for the problem.........
Let us know what it is please. Should be fairly easy to find/fix. But may be dangerous, so check it out ASAP!
Dave F. in Rhode Island
Chevy-SS is offline
post #5 of 10 (permalink) Old Feb 1st, 07, 03:30 AM Thread Starter
chucky
I have a 95 camaro. The front end has disc brakes. Not shore about the wheel type. No hub caps.
post #6 of 10 (permalink) Old Feb 1st, 07, 03:31 AM Thread Starter
chucky
Thank you
post #7 of 10 (permalink) Old Feb 1st, 07, 03:32 AM Thread Starter
chucky
Thank You very much. I will do that first thing tomorrow. I will let u know asap. Thanks again.
post #8 of 10 (permalink) Old Feb 1st, 07, 09:50 AM
I think I read on another post you just did a brake job. Check the bearings. Make sure there properly greased and adjusted.
Did you use disc brake anti-squeel?
eville is offline
post #9 of 10 (permalink) Old Feb 1st, 07, 11:07 AM
Brake job, ahhh. Then be sure and check the debris shields. Very easy to bend one and have it rubbing against the rotor, or pads may not be seated correctly.
Chevy-SS is offline
post #10 of 10 (permalink) Old Feb 1st, 07, 03:13 PM
mike
i`d bet you bent the dust shield into the rotor, or possibly rust chunks on the tone ring for abs...
kustomwerker is offline
Front wheel well question... GWM 68 Body Shop 4 Jun 11th, 06 09:44 AM
Replacement of front wheel well, what type? stevea Restoration Corner 0 Oct 26th, 05 09:03 PM
Suspension Parts List davidpozzi Brakes, Suspension & Steering 3 Feb 23rd, 04 01:54 AM
FRONT LEFT WHEEL OUT OF PLACE CESARE 327 RSA Troubleshooting 4 Jul 5th, 00 02:15 PM
