Car losses power when i give it gas - Team Camaro Tech
post #1 of 13 (permalink) Old Feb 1st, 07, 03:50 PM Thread Starter
Hello, this is my first post and I hope someone can help. I have a 1990 IROC with a 305 TPI. When I give it gas it losses power, when I let off the gas it rev's up then drops back down to idle. I replaced the cap, rotor, plugs, plug wires, checked all vacuum lines for leaks, cleaned and oiled K&N air filters, put in a new O2 sensor and drove it for an hour. None of these things worked but I did notice that when the car is in park or neutral I can rev the car with only a slight hesitation at the start. When I put the car in drive and give it gas thatís when it losses power or dies.
Any suggestions?
nece$$aryevil is offline
post #2 of 13 (permalink) Old Feb 1st, 07, 03:54 PM
Re: Car losses power when i give it gas
replace the fuel filter
67 RS marina blue, 406 ,M20 4spd, 9". car has been in my family since new!
67FREAK is offline
post #3 of 13 (permalink) Old Feb 1st, 07, 04:00 PM Thread Starter
oops, thats the first thing I did.
post #4 of 13 (permalink) Old Feb 1st, 07, 04:11 PM
mike
check the map sensor
kustomwerker is offline
post #5 of 13 (permalink) Old Feb 1st, 07, 05:02 PM
george
try driving the car with the mass air flow sensor disconnected.You will find this between the air filters and the throttle body.Some MAF sensors do not like aftermarket filters,especially oiled ones.You can carb clean the MAF hot wires first before replacing the sensor if needed.
fatblock is offline
post #6 of 13 (permalink) Old Feb 1st, 07, 05:18 PM Thread Starter
How do I check the map sensor? Can I use the same method as fatblock suggested with the mass air flow sensor?
post #7 of 13 (permalink) Old Feb 1st, 07, 08:04 PM
mike
i believe 90 is speed density, therefore does not have a mass air sensor...the map sensor(manifold absolute pressure) is a little rectangular black plastic box with a vacuum line going to it, and a 3 wire connector...try tapping on it while the car is at idle...if the idle changes, change the map...its only like 35 bucks new, so u might want to just invest in 1 anyway, as alot of drivability problems stem from a flaky map...
post #8 of 13 (permalink) Old Feb 13th, 07, 04:50 PM
bill
i agree with fatblock since aftermarket filters you oil. oil on a mass sensor throws it all off. with driveability problems and transmission not shifting right also.
jaguareats is offline
post #9 of 13 (permalink) Old Feb 13th, 07, 05:05 PM
mike
the maf sensor has a "burnoff" mode that heats up the sensor wire and cooks off any road grime and oil that may get on it, but as stated above this could be the problem if this is a maf system...but as i said earlier, 90 was the first year for speed density, hence the map sensor...this system measures manifold vacuum instead of incoming air volume...the maf sensor is inline in the air intake...its black in color. and round with a square box and 5 wire(i believe) connecter on it...the map sensor is a rectangular sensor that has a single vacuum line connected to it...its usually bolted next to the coil, but i dont remember if yours is there or plugged directly to the intake...have you ever done a fuel pump...check for pressure drop with a guage when you rev it up...also check for a plugged cat...it really sounds like a lean condition though...
post #10 of 13 (permalink) Old Feb 13th, 07, 06:31 PM
george
I think the 85 to 92 305,s use a MAF sensor.Maybe the 5.7L is what your thinking?(speed density).
fatblock is offline
post #11 of 13 (permalink) Old Feb 13th, 07, 06:47 PM
Harley
wiskeesour's Avatar
85-87 tpi- maf, 88-92 tpi -speed density. 305's 350's doesnt matter. pretty positive on that.
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #12 of 13 (permalink) Old Feb 13th, 07, 07:16 PM
george
Yep,they went to MAP in 90.The tap test on the map sensor is a good starting point as previously mentioned.Hard to keep track with all the mid year 1st 2nd design the oems throw atcha.
fatblock is offline
post #13 of 13 (permalink) Old Feb 13th, 07, 07:23 PM
mike
go to chevythunder.com for some pretty indepth tpi stuff...lots of info about them there...
69 Camaros on television and movies jsg1010z Bench Racing 35 Aug 15th, 10 05:28 PM
We are being sued about car originality shawn56 Tag Team 105 Nov 12th, 06 08:36 PM
Horrible gas milage...power valve?? J early Troubleshooting 26 Aug 24th, 06 04:33 AM
Car Running....Then lost all power to Ignition! HELP jsabowabo Electrical & Wiring 10 Jul 20th, 06 05:40 PM
Which car would you buy? South Side Goons & Hitmen Bench Racing 10 Jun 23rd, 06 10:11 AM
