earliest 67 3916323 block? - Team Camaro Tech
Tag Team De-coding tags and numbers.
post #1 of 8 (permalink) Old Aug 31st, 09, 03:31 PM Thread Starter
jeff luzzi
anyone know in their records the earliest date of a "mq" 1967 323 block?
67ssrsl78conv is offline
post #2 of 8 (permalink) Old Aug 31st, 09, 05:09 PM
Bryon
bcm66's Avatar
Re: earliest 67 3916323 block?
The 323 block was supposed to have started in June 67. I have one from a Chevelle that has an assembly date around June 25. I don't remember the exact date off hand.
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #3 of 8 (permalink) Old Jul 11th, 19, 09:39 PM
Dan
I realize this is an old thread, but another data point.
This L78 was for sale on Fleabay about a year or two ago.....
F 7 7 T0705MR 7L164951
About 400 cars after my 07B L35
My original motor is long gone, but I did find an F 5 7 406 motor as a replacement.
Has anyone seen a '67 L35 323 block?
Name:	Pad Stamp.jpg
ID:	228043   Click image for larger version
ID:	228045   Click image for larger version
Name:	casting number.jpg
Project: 67 RS, SS, L35, M20, J52, QJ Triple Black
HarrisFD is offline
post #4 of 8 (permalink) Old Jul 12th, 19, 08:49 PM
Kurt S
Kurt S's Avatar
No.
Most early 323 blocks were cast in early June, but didn't get assembled til late June or July, fwiw.
Kurt S.
CRG -
Kurt S is offline
post #5 of 8 (permalink) Old Jul 16th, 19, 08:19 PM
Dan
No.
The reason I ask is that I've seen pics and posts of a handful of early June cast 323 L78 blocks but never a 323 L35. So I began wondering if the 67 323's were L78 only?
HarrisFD is offline
post #6 of 8 (permalink) Old Yesterday, 07:54 AM
Pat
ssrocket67's Avatar
I had a 323 block L35 in a 1967 Chevelle SS. Engine stamp date 6/30/67, car was built 3rd week July 67.
1967 Camaro: True RS, Tribute SS, 350 290 HP, Muncie M20 4 SP, 12 Bolt Posi
ssrocket67 is offline
post #7 of 8 (permalink) Old Yesterday, 06:07 PM
Dan
That answers it, thanks. Do you remember casting date?
HarrisFD is offline
post #8 of 8 (permalink) Old Today, 09:06 AM
Pat
ssrocket67's Avatar
I don't recall the actual date but it was an F code. I kind of remember it was the 21st of June. The engine also had the 215 heads, the boss for the temp sensor was there but not drilled. In 1968 they mover the sensor from the intake to the head.
