81 Z with tilt wobble - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 8th, 07, 10:28 AM Thread Starter
The tilt mechanism on my 81 Z has excessive play. Looking for recommendations to have it rebuilt or is it an easy repair?
Thanks!
- John -
X77D80 is offline
post #2 of 4 (permalink) Old Apr 8th, 07, 03:54 PM
mike
Re: 81 Z with tilt wobble
there is a bearing at the upper end of the shaft that goes south from what i remember...could also be it loostened up...sounds like you`re pullin the steerin wheel...the tilt parts are under the lock plate and blinker assy...
sometimes you`re the windshield and sometimes you`re the bug...
kustomwerker is offline
post #3 of 4 (permalink) Old Apr 9th, 07, 12:19 PM Thread Starter
Is the car safe to drive? Can it break all the way and I lose my steering?
- John -
X77D80 is offline
post #4 of 4 (permalink) Old Apr 9th, 07, 05:47 PM
BonzoHansen's Avatar
There are 4 torx heads that come loose. If bad enough, it can come undone - ask me how.
http://www.carcraft.com/howto/56459/
TC Member #13
BonzoHansen is offline
Can't get door window tilt adjusted to save my life. Help! 1stgenCR Body Shop 3 Jan 1st, 07 05:57 PM
clutch fan wobble KURT Heating & Cooling 5 Jul 23rd, 06 05:24 AM
67-68 Tilt Wheel tonyvol Restoration Corner 2 Jul 2nd, 06 04:42 PM
tilt column ? zbo2 Camaro Tech 2 Mar 1st, 05 12:35 PM
Difference in horn/wheel parts, Tilt vs Non tilt for a 3-spoke wheel 69rad Interiors 5 Nov 30th, 03 02:29 PM
