Rebuilding Front Suspension - Help! - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 9th, 07, 09:30 AM Thread Starter
Smile Rebuilding Front Suspension - Help!
Hi All,
I have the right side of my front suspension off and blasted. Getting ready to powder coat everything and buy all new bushings, etc.. a couple questions:
- Do I need or should I get the offseet upper control arm shaft?
- Moog or TRW are the best. COrrect? If not, what brand should I get?
- Springs. 250 Small Block, M21, Factory Air car. I know I'm different but I want the front a little higher than it is now. ANy suggestion? Not real high but higher than the worn springs I took off. What has everyone used?
- FInally: where to buy everything? Quality, brand name and does anyone have any discounts currently?
THanks!
Pastuki
pastuki is offline
post #2 of 10 (permalink) Old Apr 9th, 07, 01:14 PM Thread Starter
Re: Rebuilding Front Suspension - Help!
No comments?
pastuki is offline
post #3 of 10 (permalink) Old Apr 9th, 07, 01:40 PM
Moog/trw replacement parts are the industry standard.
You only need offset shafts if you have camber problems, either too many or not enough shims and trouble getting the correct alignment.
I would imagine standard replacement springs for a 6 w/AC will put it where it should be, but springs are really a crapshoot, you just never know til they are on.
post #4 of 10 (permalink) Old Apr 9th, 07, 05:21 PM
"Tri-Tip"
Gary L's Avatar
I bought my Moog parts from Summit. No tax if they ship out of state and only $8.95 handling no shipping.
Link for david Pozzi site. Scroll down to link for Moog spring chart.http://www.pozziracing.com/camaro_sp...fo.htm#SPRINGS
Gary L is offline
post #5 of 10 (permalink) Old Apr 9th, 07, 05:56 PM
You may want to buy from PST (performance suspension technologies) or PSC (performance suspension components) as they have complete kit prices etc.
TJS69 is offline
post #6 of 10 (permalink) Old Apr 9th, 07, 06:34 PM Thread Starter
Ok. I checked the 2 sites. Which would be better? I know one squeeks. Which one? Can it be avoided?
Thanks!
pastuki is offline
post #7 of 10 (permalink) Old Apr 9th, 07, 08:01 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
I've had PST polygraphite bushings on the front of my 68 since '99. Haven't heard any squeaks, but not sure if I could hear them over the 2-chamber Noisemasters.
Looks like that PSC place just sells Energy Suspensions polyurethane bushing. Those will definately squeak.
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #8 of 10 (permalink) Old Apr 10th, 07, 03:22 PM
Chris
I used all PST polygraphite bushings and replacement steering components (complete front end kit from PST) 10 years ago on my previous 69 coupe w/327 and absolutely loved it. No squeaks and handles A LOT better. Oh yea, I was very hapy with the KYB Gas-A Just shocks too. I plan on ordering the same components from PST for my current 69.
Chris
72 Camaro RS/SS, 383, Dart Heads
Bucco47 is offline
post #9 of 10 (permalink) Old Apr 12th, 07, 09:38 PM
Paul
MCGOO's Avatar
Thumbs up Re: Rebuilding Front Suspension - Help!
Another 6 cylinder car????
Welcome to the dark side.
I have Hotchkiss small block springs on the front & the car sits nice & low without any suspension travel issues. KYB shocks make for a fairly firm ride, but tolerable.
I opted for tubular control arms, but stock arms & shafts will do ya just fine unless as mentioned previously by JimM you have camber problems. Moog parts used elsewhere.
Paul
'69 Camaro, 250 inline 6, EFI Turbo rebuild is running!!
, CC5S TKO 500, and more.
V8 Camaros are like navels......Everybody has one.
The Toad. 1970 base Camaro (Navel), 350, turbo 700R4, 3.73 posi, Hotchkis TVS system,
Mrs. McGoo's & McGoo Jr.'s toy
MCGOO is offline
post #10 of 10 (permalink) Old Apr 13th, 07, 05:03 AM Thread Starter
Oops! Should have read 350 small block but I'm acyually looking at a 6 cylinder right now to restore with a perfect body!
pastuki is offline
Front Suspension Pics Myfirst 69SS Restoration Corner 6 Oct 6th, 06 11:50 PM
Front Suspension Help Raysdz Camaro Tech 2 Oct 6th, 06 12:19 PM
Front Suspension Rebuild - 68 Camaro rock68cam Brakes, Suspension & Steering 5 Mar 10th, 05 04:09 PM
Front and rear suspension problems??? Erik Beckett Brakes, Suspension & Steering 3 Apr 16th, 04 09:25 AM
Front end kit in Canada Mark Yetman Brakes, Suspension & Steering 19 Mar 14th, 04 01:27 PM
