Front Coil Springs vs Coil Over's HELP - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 10th, 07, 11:39 AM Thread Starter
Looking to go with the Global West tubular control arms for my '69 and just wanted some input on staying with the original coil spring/shock set up or switching to a coil-over setup.
What are the benifits of the coil-over?
Pros and cons of both?
68RSboom is offline
post #2 of 4 (permalink) Old Apr 10th, 07, 12:10 PM
Re: Front Coil Springs vs Coil Over's HELP
my only real beef with coilover setups would be long term durability. you have a spring with little mass trying to do the job of a spring with a lot of mass- i would think they would sag faster.
also, i don't particularly like the idea of putting all that weight thru such small mounting points. yeah, you can beef up the mounting points- but then you are jsut adding unsprung weight back into the equation.
this is all from along term durability standpoint- if you only do a few hundred mile a year, i wouldn't worry about it. but i put a LOT of miles on stuff, and wouldn't want things to go wrong 200 miles from home..
on the plus side, it is easy to adjust ride height and add "wedge" if you want to.
you don't plan sincerity.
novaderrik is offline
post #3 of 4 (permalink) Old Apr 10th, 07, 12:33 PM
Matt Jones
The only real benefits are light weight, spring choices, and adjustability.
In my experience, long term durability is not an issue. I would agree that a stock spring has the potential of lasting longer, but a good quality 3" spring will last for tens of thousands of miles. We have many customers with 20,000 miles plus on their cars. Art himself has over 5,000 on his '55, and it's even jumped over railroad tracks Dukes of Hazzard style. I wouldn't worry about it.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
post #4 of 4 (permalink) Old Apr 10th, 07, 01:47 PM
i just pondered the issue recently as well. it seems the coilovers have the 'easy and quick to change' settings and look pretty cool. they are only a little more expensive, and are lighter. if you're looking to shave half second off a lap time, it might be worth it. i went with the stock style coils and shocks for the reason i think most people do: we like to 'set it and forget it'. i have no need for adjustable ride height. i personally don't think they look that cool, either, so i had no reason to buy them. if you have an itchin' for some, go for it. but i think most of us are happy with the tried and true setup the camaro came with. in either case, don't forget to enjoy the heck out of your car!
guccieng is offline
Coil Springs Upside Down? Spiked67 Brakes, Suspension & Steering 5 Oct 21st, 05 05:35 PM
Front Coil Springs FraudulentRS Brakes, Suspension & Steering 2 May 8th, 04 01:20 PM
Front Springs/ Big Block??? camaroman7d Brakes, Suspension & Steering 11 Mar 20th, 04 12:36 PM
Cutting front springs question HwyStarJoe Brakes, Suspension & Steering 12 Sep 18th, 02 06:12 AM
