Low Brake Pedal problem - Team Camaro Tech
post #1 of 11 (permalink) Old Apr 11th, 07, 07:17 PM Thread Starter
I did a search and read a lot. but it didn't answer my question My Brake pedal is low after a front disc conversion. I adjusted the rod from the pedal to the booster so that there was no pressure against the booster with the pedal touching the brake light stop. yes the clevis is in the bottom hole. I bled the brakes until one leg is bigger than the other with speed bleeders. ( go buy stock in brake fluid ) also the front right feels real tight now hard to turn the wheel with my hand with it jacked up. left side is tight too but not as tight as the right. I loosend the master from the booster and the pressure didn't change on the front. If i push against the edge of the piston with something it will loosen it up. are they suppose to be that tight?? how do i get my pedal height up?
blainedoe is offline
post #2 of 11 (permalink) Old Apr 11th, 07, 09:03 PM
Re: Low Brake Pedal problem
you don't mention bleeding the rears...
Did you change the master or add a proportioning valve?
This was a change from drum to disk, right?
post #3 of 11 (permalink) Old Apr 11th, 07, 09:56 PM Thread Starter
Hi Jim i used this complete kit http://cgi.ebay.com/ebaymotors/1967-...spagenameZWDVW yes from drum to disc. changed the master with booster and proprtioning valve under booster. i changed the rear axle seals new wheel cylinders new shoes and springs in the back. I bled the back first in this sequence b/r-b/l-f/r-f/l and went around and did again about 4or5 times. I checked the rod between the master and booster and it's right there but doesnt push against the master when i put it up there. I do have a block under driver door on the frame rail because it had disc brakes at one time in the past. didn'nt seem to have a problem with the drums working.I just need to get my pedal up a little and figure out why the front right seams not to be releasing the same as the front left? I see you ran into some of this with your brakes I read thru your post a couple of times. What can I try next I'm stumped.
post #4 of 11 (permalink) Old Apr 12th, 07, 05:52 AM
Is the pedal low, or soft? I do not believe that the calipers are self retracting, so I'm not currently concerned about the drag. If the pedal is low, try re-adjusting the rear drums. If it is soft then there must be air in the system somewhere. And finding that is the pain.
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #5 of 11 (permalink) Old Apr 12th, 07, 02:12 PM Thread Starter
Here's where I'm at now.I bled some more and think i got the brake pedal height ok. the right seems not to be releasing all the way or evenly with the left so they are sending me another caliper. now that i put the wheels back on my tires rub. they never rubbed before. the front tires rub on the back side of the fender on both sides it's like the new spindles moved everything back about 1/4" whats up with that? does the rotor hub stick out farther than or thicker than than the drum hub?? causing it to rub????????
post #6 of 11 (permalink) Old Apr 12th, 07, 08:08 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
Yep, the generic disc brake swaps all move the front wheel farther out--not sure exact how much. Mine never rubbed either until I put on a SSBC disc conversion, and afterwards they would always rub during tight parking-lot turns. They aren't rubbing at the moment because my nose is way in the air since my LS1 swap . I still need redo the front end again...
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #7 of 11 (permalink) Old Apr 12th, 07, 09:08 PM Thread Starter
hey jon what size tires are you running in the front i have 215/70-15 now and thinking of going to 225/60-15 i didn't have a new set of tires in my budget for the brake swap tires on there now still in good shape DAM!
post #8 of 11 (permalink) Old Apr 12th, 07, 09:48 PM
The rotor's wheel mounting surface is about 1/4 inch farther out. It was that way from the factory, so it's not a 'generic" issue. I learned that the hard way trying to run disc brake rallys on a drum brake car. The offset for DB caused the tire sidewall to rub on the tie rod end.
Eric
Eric Kammerer is offline
post #9 of 11 (permalink) Old Apr 12th, 07, 09:49 PM
FWIW, I ran 205 70 14s on my 68 without rubbing either side after the DB conversion.
Eric
post #10 of 11 (permalink) Old Apr 13th, 07, 10:32 AM
Jon
Rodder's Avatar
I'm running 235/60-15 on 15x7 Torq-Thrust D's right now.
Rodder is offline
post #11 of 11 (permalink) Old Apr 13th, 07, 07:49 PM Thread Starter
OK. i think i'm done went and bought new tires (225/60-15) to solve the rubbing issue wish i would have known about the rotors sticking out farther. Not that it would have changed anything but at least would have been expecting it and not have been such a surprise. I would like to thank everyone for there help and comments exspecialy david pozzi for taking the time to e-mail me I know he must be very busy but he still takes the time and puts out the effort to help thanks david. and to everyone else. Just a reminder to everyone doing the conversion. " your rotors will stick out a little futher " Good upgrade I had get up and go, NOW I have a lot of woooooe : beers on me. Team Camaro's the place
brake sticking and pedal is also importkiller69ss Troubleshooting 3 Dec 25th, 05 10:14 AM
Brake Problem 69X11SS Brakes, Suspension & Steering 4 May 17th, 05 11:37 AM
Help Hard Brake Pedal /Bleeding phoenixdawg Brakes, Suspension & Steering 2 Mar 21st, 05 02:48 AM
Brake Pedal cpodeep Brakes, Suspension & Steering 28 Jan 11th, 04 10:03 AM
brake pedal seems to high sweems Tech 2000 12 Mar 1st, 01 04:17 PM
