69 steering box - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 15th, 07, 07:30 PM Thread Starter
69 steering box
I am bring back to life a 69, I have rebuilt the front susp. and added 2" lowering springs. I would like to change the existing manual steering box with a power one. I see there is different options as far as gear ratios. Does anyone know which one seem to work the best and where I can find one reasonable. It is going to be a driver. (not a track car) Dont know what engine I will go with yet LT1 or a 383. any help is appriciated.
basketcase is offline
post #2 of 6 (permalink) Old Apr 15th, 07, 07:42 PM
Re: 69 steering box
Our "steering of choice" for a couple years now has been the "thirdgen box" Hundreds of us have done it, and it works great. You get a rebuilt steering box from a late 80's camaro with "special suspension" (irocZ or WS6 transam) and a couple lil peices to adapt it.
It will give you 2 1/2 turns lock to lock, with a high effort late model feel.
Brian Lewis took the time to write up the details http://69camaro.nextmill.net/steering.html and a search for "thirdgen steering" will give many dozens of hits.
post #3 of 6 (permalink) Old Apr 15th, 07, 08:05 PM Thread Starter
Re: 69 steering box
Does it bolt up in the same location using the same holes? On a scale of one to ten how hard is this retrofit?
post #4 of 6 (permalink) Old Apr 15th, 07, 08:13 PM
Re: 69 steering box
yes. It's a peice of cake. read Brian's page, do a search.
If replacing the existing steering box with a new identical one is a 4, this is a 5.
post #5 of 6 (permalink) Old Apr 15th, 07, 08:18 PM Thread Starter
Re: 69 steering box
I will check in to it thanks for the help!!!!cheers
post #6 of 6 (permalink) Old Apr 15th, 07, 09:47 PM
Blaine
Re: 69 steering box
My advice is do it.
Don't forget to post your results
it's good for the thread
My 67 RS/SS/396
blainedoe is offline
Installed 670 P.S. box... 69 merlinpro565 Brakes, Suspension & Steering 0 Jul 31st, 06 10:48 PM
1968 Z28 Steering Box - Rebuildable? chedderboy Restoration Corner 5 Jan 24th, 06 02:26 PM
Need help with 69 Z28 Manual steering box dragsterman Bench Racing 5 Sep 18th, 05 04:39 PM
steering box swap info needed. fyrefighter103 Brakes, Suspension & Steering 5 Apr 13th, 05 06:51 AM
Front end kit in Canada Mark Yetman Brakes, Suspension & Steering 19 Mar 14th, 04 01:27 PM
