Going from manual to power brakes..need that spring on the pedal? - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 16th, 07, 11:40 AM Thread Starter
Dan
so i'm going from manual brakes to power. i read that you should have the MC push rod hook up to the lower point in the brake pedal. in the process of that i noticed that there's a piece that hooks up to a spring where it pulls the pedal back up after you push it down.
now going to power brakes do i still need to hook this spring back up? the pressure from the booster seems to push the pedal back no problem. the spring also snags on part of the bracket when i use the lower hole.
so should i leave the spring out?
mktbully is offline
post #2 of 4 (permalink) Old Apr 16th, 07, 11:52 AM
Kevin
KevinW's Avatar
Re: Going from manual to power brakes..need that spring on the pedal?
You do not need the spring or eye bracket. the booster has an internal spring to push the pedal back.
Kevin
KevinW is offline
post #3 of 4 (permalink) Old Apr 16th, 07, 03:27 PM
Blaine
Nope don't need it.
Don't forget to post your results
it's good for the thread
My 67 RS/SS/396
blainedoe is offline
post #4 of 4 (permalink) Old Apr 16th, 07, 09:30 PM
Upper hole gets another part instead... brakelight striker.
rickscamaros.com PT-83
If I didn't learn it from my my mentors, I learned it as a result.
ohcscott is offline
Manual vs power steering preference Gettingbackintoit Brakes, Suspension & Steering 28 Jan 4th, 07 12:39 PM
power vs. manual sremington Brakes, Suspension & Steering 4 Dec 16th, 06 10:16 AM
68 manual drum to power conversion lookingforparts Restoration Corner 1 Nov 27th, 06 04:14 AM
Effect of pumping power brakes at idle Gary L Engine 4 Jul 3rd, 06 01:06 PM
Brakes - Mechanical to Power ? Superman85 Brakes, Suspension & Steering 3 Jun 10th, 06 07:21 PM
