Suspension/wheel question - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 16th, 07, 03:38 PM Thread Starter
AJ
What is your opinion on Flaming river's manual rack and pinion kits for a 68' Camaro and if I purchase this what els will I need to make this work? another question I have is will 17" front wheels rub the front end if I lower the car and will the rear rub aswell if it is lowerd?
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #2 of 2 (permalink) Old Apr 16th, 07, 10:35 PM
Re: Suspension/wheel question
there was a long tread on flaming river rack and pinion set ups recently, just use the search function
as for the wheels, your answer is possibly.
it all depends on what backspacing and how wide your rims are and what size wheels you have
If you know what your rim width and backspacing are and what size tires you have, I suggest the search function again
400bird is offline
Engine Harness Question ironhorse78247 Electrical & Wiring 8 Nov 17th, 06 09:16 AM
am fm radio question flyers69 Electrical & Wiring 3 Jun 28th, 05 08:31 PM
carb and exhaust question for 67 RS small block Kyson Engine 2 Jun 25th, 05 12:40 PM
69 fuel line question - vapor return or not? Eric Kammerer Engine 7 Jun 11th, 05 06:08 PM
