Need Disc Brake help? - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 16th, 07, 05:58 PM Thread Starter
Question Need Disc Brake help?
I just installed a CCP 4 wheels power disc brake kit on my 1969 camaro. The install was very easy. The master cylinder and all of the brakes bleed fine. When bleding the brakes the pedal had a consistant pressure all the way to the floor and no air bubbles where coming out of any of the calipers. When I start the car the pedal is very soft, almost no pressure all the way to the floor? What could be causing the pedal to have no resistance when the car is running? Thanks
Black Z is offline
post #2 of 9 (permalink) Old Apr 16th, 07, 06:14 PM
Re: Need Disc Brake help?
Is the rod in the correct hole on the pedal.
68 Camaro~LSx ~all motor
post #3 of 9 (permalink) Old Apr 16th, 07, 06:15 PM
you still have air, keep bleeding.
when all the air is gone, hulk hogan couldn't get that pedal to the floor, running or not.
post #4 of 9 (permalink) Old Apr 16th, 07, 06:20 PM
Blaine
it was easy because your not done yet. now the hard part is to make them work. "Just kidding with you" Did you bench bleed the master. If you didn't your going to have some troule getting it. I bled mine without the car running seem to get a better feel for whats going on. sometimes you have to bleed a lot of brake fluid thru there because sometimes there is air trapped way up front and it takes a lot to get it out. tap on the master and the calipers as you bleed just incase there is some of those " champagne" bubbles in there.
Don't forget to post your results
it's good for the thread
My 67 RS/SS/396
blainedoe is offline
post #5 of 9 (permalink) Old Apr 16th, 07, 07:58 PM Thread Starter
I did bench bleed the master cylinder. The rod is in the correct hole on the pedal. I did pressure bleed the brakes until no more air/bubbles were coming out, then I manually bled each caliper to confirm that no air was coming out. The pedal had firm pressure the entire time I was manually bleeding them, but as soon as I started the car the pedal has no pressure and went all the way to the floor? If there is still air in the system and if I bleed each caliper and no air is coming out, then how will I know when all of the air is out? How should I proceed? Thanks
Black Z is offline
post #6 of 9 (permalink) Old Apr 16th, 07, 11:55 PM
Blaine
just keep bleeding. start on the wheel furthest away right rear, left rear, right front, left front. you may not see any air for a bit then all of a sudden some may come out. if your pedal goes all the way down you must have air in there somewhere? unless you have a leak?? if you let your master get too low and suck air you must start all over. keep an eye on that. i would push about a full master thru each caliper then check it. don't let it suck air back into the caliper either. speed bleeders are a good investment.don't give up. I pushed on my pedal so much one leg is bigger now! LOL
My 67 RS/SS/396
post #7 of 9 (permalink) Old Apr 17th, 07, 12:15 AM Thread Starter
I do not have any leaks, I will try to bleed them again tomorrow. Thanks
Black Z is offline
post #8 of 9 (permalink) Old Apr 17th, 07, 05:10 AM
Jerome
Even though there new caliper's you might have one hanging up (a piston),I did and had no pedal press. replaced the bad one and walla pedal press.not saying its your prob. just a though...Happy Motoring
1972 Nova SS , 350, Auto, AC, Survivor
68Lemans blue is offline
post #9 of 9 (permalink) Old Apr 17th, 07, 09:50 AM
Rear calipers which are parking brake integral must be manually adjusted when installed or there will be excessive lining clearance, causing a low pedal. If you have this type of rear calipers, make sure you have them adjusted.
If I didn't learn it from my my mentors, I learned it as a result.
ohcscott is offline
Need Help with 68 disc brake conversion BobCamaro68 Brakes, Suspension & Steering 17 Mar 20th, 15 09:22 PM
disc brake upgrade, best way to proceed with what I have Pete Mag Brakes, Suspension & Steering 2 Mar 3rd, 07 08:06 AM
A few questions about a drum to disc front brake conversion... Cougar207 Brakes, Suspension & Steering 2 Sep 10th, 06 10:26 PM
drivers side rear disc brake won't bleed ratbikeharley Brakes, Suspension & Steering 4 Aug 1st, 06 06:41 PM
Brake Bleeding the right way WillS Brakes, Suspension & Steering 0 Feb 14th, 05 03:45 PM
