Proportioning Valve inputs needed - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 17th, 07, 10:50 AM Thread Starter
Ken
Question Proportioning Valve inputs needed
I am in process of rebuilding a 67 RS Convertible and just now discovered a leak from the rear cover boot on the orginal (?) proportioning valve. This ride has had the front disc brake conversion (I think they are from a 69 or later with the single piston caliper) and standard drums in the rear. Do I just replace the unit ($195) OR would I be better off using my adjustable proportioning valve with its 0 to 3000 psi gage attached? It looks to me the original valve is controlling the front discs is this correct or should the porportioning valve control the rears? How would I adjust the valve with the gage attached?
Ken
Rides:
67 Camaro RS Vert
05 Corvette Vert
X-Rides
04 SSR
57 Nomad
Nomadkenn is offline
post #2 of 7 (permalink) Old Apr 17th, 07, 10:55 AM
Re: Proportioning Valve inputs needed
The original valve by the master cylinder is a metering (aka holdoff) valve, not a proportioning valve.
See the spirited discussion in this thread...
https://www.camaros.net/forums/showth...=holdoff+valve
Eric
Eric Kammerer is offline
post #3 of 7 (permalink) Old Apr 17th, 07, 12:39 PM
Do not use an adjustable prop valve for the front brakes. You're better off just eliminating the front brake valve altogether than doing that.
If I didn't learn it from my my mentors, I learned it as a result.
ohcscott is offline
post #4 of 7 (permalink) Old Apr 17th, 07, 12:47 PM Thread Starter
Ken
I think you are speaking about the brake splitter block (low pressure switch which mounts beneath master cylinder, the pro valve is mounted to the power booster with a nut on the left side.
Ken
Rides:
67 Camaro RS Vert
05 Corvette Vert
X-Rides
04 SSR
57 Nomad
post #5 of 7 (permalink) Old Apr 17th, 07, 01:10 PM
David Pozzi
davidpozzi's Avatar
If the valve has all the brake lines running into and out of it it's a combo valve from a later model car, common in conversions. You can either replace it with new, or bypass it and run an adjustable proportioning valve in the rear line only. I'd remove any pressure gage, it won't tell you anything unless you have one in both front and rear lines, and you adjust the brakes by feel anyway, not the gage. The gage is a possible leak or failure source and should not be used unless it has a definite purpose to serve, - in my opinion.
If it's a separate roundish valve with big nut and is above the brake light switch/splitter, then it's a hold off valve for the front brakes. You can remove this valve with no problems or adjustments. I have a full explanation of this valve on my web page below.
I'm in Salinas too, we'll have to meet some time.
davidpozzi is offline
post #6 of 7 (permalink) Old Apr 17th, 07, 01:43 PM Thread Starter
Ken
You sound like the "MAN", yes let's get together sometime. Thanks for the input I will PM you with some more questions. I think you will like the ride I am putting together!
Ken
Rides:
67 Camaro RS Vert
05 Corvette Vert
X-Rides
04 SSR
57 Nomad
post #7 of 7 (permalink) Old Apr 18th, 07, 01:55 AM
New seal kits are available through Heartbeat City. I fitted a kit due to the same rear leak and..
BlackoutSteve is offline
proportioning valve gm torch red Brakes, Suspension & Steering 15 Mar 21st, 07 06:26 PM
Lifter adjustment, warm or cold? gotsnappy Engine 32 Apr 20th, 06 06:41 PM
New master & Proportioning valve problem Procurement_man Brakes, Suspension & Steering 3 May 4th, 03 11:53 AM
roller rockers Lil Greg Performance 9 Feb 12th, 01 03:26 AM
valve train and cam help needed MY FIRST 69 Tech 2000 1 Nov 15th, 00 01:35 AM
