leaf spring recommendation - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 17th, 07, 04:45 PM Thread Starter
Russ
Going to replace the 5 leaf multi set up I have now with new ones and going to go with poly bushings and pads. I'm trying to eliminate wheel hop without the use of traction bars , if thats even possible. Just wondering what leaf springs some of you are useing , and what the difference is between the 4 and 5 leaf set up. The springs that are in there now are old and should be replaced anyway. Finally if this does not solve the dreaded wheel hop issue , I'll be asking you this. which traction bars would be recommended to eliminate this issue? Thank you all for taking the time to read all this I know it's long winded. lol.
Russ
1969 RS conv,hugger orange,396 4 speed,373 12 bolt posi.
19694speed is offline
post #2 of 3 (permalink) Old Apr 17th, 07, 04:59 PM
Paul
PDQUICK's Avatar
Re: leaf spring recommendation
I'm running 5 leafs with poly bushings, no traction aids and I have zero wheel hop. The springs are old Rancho Challenger GT IIIs that I had sitting around the shop. They were designed specifically to improve handling and eliminate the need for traction bars. Unfortunately, they haven't made them for a long time!! Somebody else might make something similar?? I don't drag race this car a lot and wanted it to handle better than it might with traction aids.
I'm also running a 9" rear that is solidly U-bolted to the leafs. (no rubber mounting pads as on the original GM setup) and a sticky, race compound, DOT tire. The car hooks just great and never hops.
That said, I believe that most will agree that you can't go wrong with a set of Cal-Tracs!! Not cheap, but money well spent.
Paul D.
68RS/Z28 Klone, Long rod 357 , T-56, 3.89 9"
Move with direction or lose your direction!
PDQUICK is offline
post #3 of 3 (permalink) Old Apr 17th, 07, 06:35 PM
David Pozzi
davidpozzi's Avatar
We put Hotchkis leafs on my wife's 73 Camaro and run 450 hp through it with no wheel hop first gen Camaro leafs are the same. Global west L1 leafs may work but warn if HP is high enough they may have problems. These are lowering/handling leafs so if you want the car to sit stock or higher, use something else.
davidpozzi is offline
Leaf Spring Sag KRhat Brakes, Suspension & Steering 0 Aug 10th, 06 07:53 AM
leaf spring pads 19694speed Brakes, Suspension & Steering 7 Aug 6th, 06 04:49 PM
leaf spring thoughts kgmunro Brakes, Suspension & Steering 0 May 5th, 06 09:41 PM
New leaf spring bushing question Brackneyc Brakes, Suspension & Steering 5 Aug 5th, 05 05:34 PM
broken leaf spring. help! Qwank Brakes, Suspension & Steering 6 Aug 3rd, 05 04:30 AM
