Rag Joint - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 17th, 07, 07:16 PM Thread Starter
thewebb1's Avatar
Rag Joint
Where would you find a rag joint for a 67 with power steering. All the ones I see for sale are for manual steering. Any body Know?
P.S. What's the difference?
67 Camaro RS350SS (already restored) 68Convertible(future project)
68 Coupe(restoring)On hold
Gave to friend.
67 Convertible (restoring)
67 Coupe(parts car for now)
72 Chevelle Malibu
2-69 Jaguar xke roadsters (appeasing the wife)
thewebb1 is offline
post #2 of 9 (permalink) Old Apr 17th, 07, 09:21 PM
"Tri-Tip"
Gary L's Avatar
Re: Rag Joint
That part is listed in their catalogue. #7828871
http://www.oldmusclecars.com/
Gary L is offline
post #3 of 9 (permalink) Old Apr 18th, 07, 07:02 AM
Re: Rag Joint
Up until 1976 the power steering gear input shaft was 13/16 inch diameter. All manual gears were 3/4 inch diameter. In 1977 the power gear input shaft was changed to 3/4 diameter.
So if you have a car with the old style power gear (one with the 13/16 input shaft) the 7828871 flexible coupling is the correct GM part number. I do not find that part number on the GMPartsDirect websight. So I don't think that GM dealers carry it any longer. But is seems to be available at http://www.oldmusclecars.com/
If the flange on the flexible coupling has a flat, it will only install one way on the gear.
However, if the flexible coupling does not have a flat, the flexible coupling will install on any of the 36 serrations on the gear input shaft. You will need to follow these instructions in order to install it correctly:
Set the gear exactly on the center of its pitman shaft sweep (count total revolutions of the input shaft - full lock to full lock; then come back from full lock exactly 1/2 the number of total revolutions.) Then with the gear exactly on center, you will need to install the flexible coupling with the stop pins at 6 and 12 o'clock. The head of the attaching pinch bolt should be pointing straight up, passing through the 9 o'clock quadrant.
JIML82
JIML82 is offline
post #4 of 9 (permalink) Old Apr 18th, 07, 04:54 PM
Banned
Re: Rag Joint
Do a search under me on this b/c you need the high-strength steel screenwire re-inforced rubber washer, imho!!
pdq67
post #5 of 9 (permalink) Old Apr 18th, 07, 08:32 PM
Re: Rag Joint
The screen that is molded into the face of the flexible coupling disc is for electrical continuity. With just a plain rubber disc, the flexible coupling may cause the steering column to be electrically isolated from the rest of the car. If this happens, you will not be able to blow your horn. Early flexible couplings (up until the early 1970s) had a brass strip or a wire that was installed around the center of the flexible coupling. This was a ground strap or wire that enabled a ground path to exist from the steering column shaft down through the flexible coupling, then down through the steering gear into the frame.
Starting in the early 1970s the screen was introduced. It did not add any durability to the rubber disc. It was a more reliable ground path for you to be able to blow your horn.
JIML82
JIML82 is offline
post #6 of 9 (permalink) Old Apr 19th, 07, 02:31 PM
Banned
Smile Re: Rag Joint
I know Jim, we've went through this before, but I'm here to say, my rubber washer is as tough as a steel-belted tire tread!!
pdq67
post #7 of 9 (permalink) Old Jul 1st, 07, 09:57 AM
Re: Rag Joint
JIML82
Jim, Thanks. I was just trying to figure out how to re-install the ground strap when I decided to come search the forum. My new rag joint does have the steel mesh, so I guess I'm good to go.
all gave some
MY SON GAVE ALL
68DaveV is offline
post #8 of 9 (permalink) Old Jul 1st, 07, 01:04 PM
Banned
Re: Rag Joint
Rubber washer's tough as nails too, isn't it!!
Try bending it double and don't get bit by the screen wire ends!!
pdq67
post #9 of 9 (permalink) Old Jul 1st, 07, 04:17 PM
Re: Rag Joint
It does seem tough, but man those wires tear up your hands. It didn't exactly "slip" on the spline and trying to work it on it's hard to avoid the wires. Ouch.
all gave some
MY SON GAVE ALL
68DaveV is offline
Rag joint pin gap in flange? Bry68 Brakes, Suspension & Steering 3 Mar 4th, 07 02:42 PM
69 Camaro - rag joint sources Rybar Brakes, Suspension & Steering 8 Jan 17th, 07 09:09 PM
Lee Mfg Rag Joint Kit Rons68 Brakes, Suspension & Steering 22 Mar 6th, 06 02:34 PM
Rag Joint Removal foooz Brakes, Suspension & Steering 2 Nov 7th, 05 05:29 PM
Bad Rag joint? How do you tell? faninc Brakes, Suspension & Steering 4 Sep 8th, 05 06:53 PM
