69 front pwr disc master cylinder question - Team Camaro Tech
post #1 of 1 (permalink) Old Apr 18th, 07, 08:35 AM Thread Starter
rob
I have both new rear drum wheel cylinders installed along with new axle lines. The front seems ok so I didn't mess with it. Im trying to get fluid to the rear now that I finished my rear brake job. When I pump the brakes down, I only notice a squirt in the front chamber of the master cylinder. Should I get a squirt in the rear MC chamber as well? I am having a problem getting fluid back there. I even put a funnel and put fluid into the rear lines and out the bleeder in the wheel cylinder to make sure it flowed. It does. Trouble is normal bleeding seemed to only bleed out the stuff I put in. While looking at the master cylinder with the cover off, I noticed only the front squirts when I press on the pedal. Is this normal?? THANKS for any advice or tips.
rob
firstrs is offline
Front disk master cylinder esahlin Brakes, Suspension & Steering 4 Apr 2nd, 07 03:33 PM
Master cylinder question for 67 camaro Gignem Brakes, Suspension & Steering 2 Apr 29th, 06 08:23 PM
Master Cylinder for Disc Brakes? ItDoRun Brakes, Suspension & Steering 3 Aug 22nd, 05 09:35 PM
Master Cylinder Question peters76 Troubleshooting 5 Oct 2nd, 02 04:57 AM
4 disc master cylinder SOUTHWNR Brakes, Suspension & Steering 6 Jan 17th, 02 01:09 PM
