HELP!! no brakes,new vert, nice day, wana cruise - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 22nd, 07, 07:08 AM Thread Starter
jimmy
Hello all, I am brand new this morning. Just purchased 1967 ss 350 convertible, 4 speed, front disc brakes. Brought it home last weekend, brakes seemed ok. I went DMV and got tags (always a treat). Wanted to take on initial run so I checked the fluids. Front Reservoir empty !! So I filled it up and enlisted wife for pumping duty. Right front caliper ---no air. Left front-- nothing but air. Filled and pumped two complete reservoir's worth. No luck. No visable leaks. But when you go to refill master cylinder, front reservoir is full of tiny bubbles. Question: is my master cylinder gone ? OK Guys be gentle, this is my first time. Thanks in advance. Gypsy Jim
gypsy jim is offline
post #2 of 7 (permalink) Old Apr 22nd, 07, 09:17 AM
john
wagonman's Avatar
Re: HELP!! no brakes,new vert, nice day, wana cruise
you really need to remove your tires,pull the rear drums and do a visual inspection of all four corners!! if the master was empty,there probably is a reason..
we need to keep you around!!!!
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #3 of 7 (permalink) Old Apr 22nd, 07, 09:21 AM
usually leaking wheel cylinders is a problem w/ these cars. Sometimes you can't even see the leaks. They rust and then sieze up causing problems.
m21man is offline
post #4 of 7 (permalink) Old Apr 22nd, 07, 01:11 PM
Blaine
you have a leak some where brake fluid just doesn't evaporate! By the way jimmy welcome to team camaro you will get a lot of help and info here.
Don't forget to post your results
it's good for the thread
My 67 RS/SS/396
blainedoe is offline
post #5 of 7 (permalink) Old Apr 22nd, 07, 05:01 PM
bill
if you keep getting air in master sounds like you got a bad brake line. when you release the brake it sucks in air.
jaguareats is offline
post #6 of 7 (permalink) Old Apr 22nd, 07, 10:00 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
I agree with everyone else here, you need to find where it was leaking and fix that. One additional thing though: if you sucked the master cylinder dry, you need to pull it out and bench bleed it.
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #7 of 7 (permalink) Old Apr 23rd, 07, 04:20 PM Thread Starter
jimmy
Thanks to everyone for the warm welcome and good advice. I am in the process of tracking down the problem. You gotta have stop before you can go. My car is a long way from looking like most of yours but will post pics asap. Thanks again, Jimmy
Nice December day, brought her outside to idle a bit jr68 Bench Racing 9 Dec 17th, 06 04:05 PM
A few quick pics of the '69 RS Z/28... SinCityRSZ28 Bench Racing 15 Dec 12th, 06 05:36 PM
nice day to have a 69 vert out for a ride angelglo Bench Racing 2 Nov 19th, 06 12:47 PM
Nice day finally- pic of the 69 Tubbed69 Camaros.net Site Help Discussion 0 Apr 10th, 05 07:18 PM
Nice cruise night at Hooters! Jeff H Bench Racing 3 Jul 30th, 04 06:16 PM
