disk brake conversion on my'68 - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 22nd, 07, 11:59 AM Thread Starter
George
I bought a '68 recently and it has an unfinished disc brake conversion on the front. I'm not sure how to tell what system he started with. It already has the discs on it and caliper brackets. the calipers are worthless and were left in the rain.
I also have a '79 Elcamino with discs that I am parting out. Is there any chance of this stuff working with what he started? I know this is hard to answer since I can't identify what I have, but what are common sources for these conversions?
Texas68RS is offline
post #2 of 5 (permalink) Old Apr 22nd, 07, 01:03 PM
Blaine
Re: disk brake conversion on my'68
how many pistons do the caliper have? if for example it's a single which would be for a 69 ( this is what most conversions are) you should be able to go to your local parts store and just replace it. as long as you don't change to say a 4 piston from 67. just make sure there the same. as far as swapping different years to work i can't help on that. i guess you could take the 79 caliper and try to bolt it to your bracket then you would know?
Don't forget to post your results
it's good for the thread
My 67 RS/SS/396
blainedoe is offline
post #3 of 5 (permalink) Old Apr 22nd, 07, 09:08 PM Thread Starter
George
single piston calipers were in the box. They looked like rebuilt ones at one time. I can use them for cores, but not sure what year make model I need to get.
post #4 of 5 (permalink) Old Apr 22nd, 07, 10:40 PM
Blaine
I would say 69 camaro.
My 67 RS/SS/396
post #5 of 5 (permalink) Old Apr 23rd, 07, 07:17 PM
Darrell
i did a drum to disc on a 69 RS with 71 chevelle parts
Seneca SS is offline
LT-1 rear brake conversion elitecustom68 Brakes, Suspension & Steering 2 Dec 3rd, 06 02:33 PM
Disk brake conversion Trakspeed Brakes, Suspension & Steering 1 Jan 21st, 06 06:37 AM
'68 Disk Brake Conversion fast_eddie Brakes, Suspension & Steering 3 Jul 14th, 05 09:30 PM
HELP with Disc Brake conversion houston68 Brakes, Suspension & Steering 6 Jan 25th, 05 10:50 AM
Disk Brake Conversion - how it's going gb3080 Brakes, Suspension & Steering 5 Oct 14th, 03 07:09 AM
