02 subframe in a 69 - Team Camaro Tech
post #1 of 11 (permalink) Old Apr 23rd, 07, 04:21 PM Thread Starter
Cliff
n269chvy's Avatar
02 subframe in a 69
What is involved in putting a 02 Camaro subframe in a 69 Camaro
n269chvy is offline
post #2 of 11 (permalink) Old Apr 23rd, 07, 05:05 PM
Welcome Back - Senior Tech
Re: 02 subframe in a 69
Yeesh, could be wrong but I think a lot. The cars are different in width and I think the 02 camaros frames were weld in.
the learning curve is....expensive
1969 Camaro
bearcat44 is offline
post #3 of 11 (permalink) Old Apr 23rd, 07, 05:11 PM
call that one company that will take your shell and $40k and put the body on a late model Camaro floorpan.
you don't plan sincerity.
novaderrik is offline
post #4 of 11 (permalink) Old Apr 23rd, 07, 05:22 PM Thread Starter
Cliff
n269chvy's Avatar
I am not Donald Trump lol, just didnt know how much trouble, found a 02 Z-28 6 speed car with a bottom end knock for 3k, and was just thinking what I could use
n269chvy is offline
post #5 of 11 (permalink) Old Apr 23rd, 07, 05:41 PM
for 3 grand u could bolt in a whole new front clip with coil over sus
with a lot less work just a thought keep my updated if you try it though it could be interesting
bob22 is offline
post #6 of 11 (permalink) Old Apr 23rd, 07, 06:11 PM Thread Starter
Cliff
n269chvy's Avatar
I know the rear brakes will bolt up and the 6-speed is tempting as well
n269chvy is offline
post #7 of 11 (permalink) Old Apr 24th, 07, 09:03 AM
www.retrorides.com
Musclerodz is offline
post #8 of 11 (permalink) Old Apr 24th, 07, 09:27 AM
Matt Jones
I wouldn't bother.
The car that has a knock has probably been run hard, which means I wouldn't plan on using the motor or transmissions, which IMO, is the only useful parts. I'd sell the rear discs and junk the rest. The suspension isn't that great.
You can buy a LS1 and T56 with very low miles (without a knock) for a little more.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
post #9 of 11 (permalink) Old Apr 24th, 07, 04:34 PM
Banned
The only S/F conversion I would do would probably be a 2nd Gen. into a 1st Gen. car unless I had more money, then I'd go first class.........
You get front steer;
Can use Big Car and 1Le 12" disc brakes on it;
A better front roll center height; and
A 2nd Gen. one would be cheap and easy to find..
As always, jmho..
pdq67
post #10 of 11 (permalink) Old Apr 24th, 07, 05:13 PM
Tony
4th gen subframe is useless without the inner fender wells. Those fender wells are required to mount the top of the strut/shock and also the upper A-arm. The lower "subframe" on a 4th gen looks more like a crossmember that just bolts in. It is about as useful as a boat anchor.
Co-Founder,
69 Camaro SS convertible
70 Chevelle SS 454
Online Garage:
Nine Ball is offline
post #11 of 11 (permalink) Old Apr 24th, 07, 09:27 PM
67 Camaros Rock
Joe Harrison's Avatar
3 K builds a killer sub frame for a 1st gen. You can almost get a bolt in for that amount and have a very trick ride. Go over to www.Pro-Touring.com and check out some of the stuff being done.
For sale over there is a DSE coil overed sub frame with what i think has the gulstrand mods done. It's just a sub and asking price is about 1K might be taking less.
Joe
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
69 Z28 Exhaust System Questions??? W.A.C Camaro Tech 14 Mar 16th, 07 09:51 AM
subframe bushings on a 69 camaro greenman Body Shop 3 Sep 19th, 06 10:52 AM
Fatman Fab subframe Steviej70 Brakes, Suspension & Steering 0 Feb 13th, 06 03:21 PM
DSE Subframe 67Builder Brakes, Suspension & Steering 12 Feb 25th, 05 05:20 PM
