Rear brake drums used on a 69 camaro coupe - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 24th, 07, 02:49 PM Thread Starter
bigsteve
Question Rear brake drums used on a 69 camaro coupe
My 69 camaro coupe came standard with non ribbed rear brake drums. Would like to know if I could use ribbed rear brake drums from a 1968 camaro. They are both 9 1/2 inch diamiter if anyone knows for syre please let me know. Thanks Steve
bigsteve is offline
post #2 of 3 (permalink) Old Apr 24th, 07, 03:01 PM
bill
Re: Rear brake drums used on a 69 camaro coupe
they must be from different manufacturer but will fit 67-69 all same.
jaguareats is offline
post #3 of 3 (permalink) Old Apr 24th, 07, 03:01 PM
The ribbed rear drums must be from a later model car. All three 1st gen years had smooth rear drums. If both the diameter and depth/contact area are the same between the two types, they'll work fine.
Eric
Eric Kammerer is offline
69 Camaros on television and movies jsg1010z Bench Racing 35 Aug 15th, 10 05:28 PM
69 camaro coupe rear spring removal Help bigsteve Brakes, Suspension & Steering 15 Apr 24th, 07 02:55 PM
69 rear disc brake question fmercado69 Brakes, Suspension & Steering 4 Apr 17th, 06 11:42 AM
69' Camaro, Nova 10 bolt rear drive shaft cutting Markus Transmission & Driveline 1 Feb 4th, 06 06:22 PM
My first post...need disc brake upgrade for 69 Camaro. 1320King Brakes, Suspension & Steering 5 Nov 22nd, 05 05:19 PM
