1969 Camaro Shackle bolts - Team Camaro Tech
post #1 of 14 (permalink) Old Apr 25th, 07, 03:29 PM Thread Starter
bigsteve
Have a 69 camaro that I am in the process of removing the rear and the right bottom side shackel bolt is a carrage bolt on one side and the left side is a threaded rod with nuts on both ends, I know the threaded rod is not original? Would like to know if the carage bolt is original or some other type of special square bottom bolt? Thanks Steve
bigsteve is offline
post #2 of 14 (permalink) Old Apr 25th, 07, 03:41 PM
Re: 1969 Camaro Shackle bolts
That bolt should be welded onto the shackle. Just take a wrench and unscrew the nut. Use plenty of PB blaster also. Also easier if tank is dropped but not necessary.
fireeater is offline
post #3 of 14 (permalink) Old Apr 25th, 07, 04:21 PM
Kevin
KevinW's Avatar
Dave, no bolt was welded to the shackles. rusted on yes, welded no.
Steve, the originals are special shouldered carriage bolts. Most parts places carry shackle bolts and kits.
Here is a pic. the shorter one is for 1st gens, the longer is for 70 and up.
Kevin
KevinW is offline
post #4 of 14 (permalink) Old Apr 25th, 07, 04:24 PM
DjD
DjD's Avatar
I've never seen the carrage bolt welded to a shackle... The carrage bolt is correct from the factory and each shackle half will have one round hole and one square hole for the carrage bolt to go through. The upper and lower bolts go in opposite of each other.
...Dennis
DjD is offline
post #5 of 14 (permalink) Old Apr 25th, 07, 04:41 PM
Banned
Smile Re: 1969 Camaro Shackle bolts
The holes and bolts are staggered so you can leave the top one in the frame bushing and you then pull the bottom one out from the outside so you don't have to drop the tank to replace springs if I remember right.....
OR visa-versa, I forget!! BUT whatever, you shouldn't have to drop the tank to R&R springs is what I'm getting at....
pdq67
post #6 of 14 (permalink) Old Apr 25th, 07, 06:18 PM
Kevin, I stand corrected. My new shackles are welded. The originals are as you described. My bad.
post #7 of 14 (permalink) Old Apr 25th, 07, 07:00 PM Thread Starter
bigsteve
Thanks, Another question should the shackle move forward and back at the top bolt bushing area when the spring/axel is moved up and down?
bigsteve is offline
post #8 of 14 (permalink) Old Apr 25th, 07, 07:06 PM
DjD
DjD's Avatar
Yes, to some degree.
...Dennis
DjD is offline
post #9 of 14 (permalink) Old Apr 26th, 07, 02:22 AM Thread Starter
bigsteve
Thank,another question are the nuts for these shackle bolts a 1 time use?
bigsteve is offline
post #10 of 14 (permalink) Old Apr 26th, 07, 03:20 AM
Harry
dawg's Avatar
on any suspension part as critical as that i would replace with grade 8 hardware.
434 stroker
US Navy retired
dawg is offline
post #11 of 14 (permalink) Old Apr 26th, 07, 12:50 PM Thread Starter
bigsteve
Does anyone out there know a mail order company that will sell just the nuts and bolts I called around localy and they only have the shackle kits? thanks Steve
bigsteve is offline
post #12 of 14 (permalink) Old Apr 26th, 07, 03:13 PM
Ted
Rick's has just the nuts in their catalog. Not the bolts. Check ebay. If you are replacing spring and shackle bushings the shackle kits usually have rubber bushings. If you are replacing with urethane bushings the shackle kit bolt may be to long as compared to stock bolt. At least in my case when I replaced my rear suspension. I needed to use stock length bolts with urethane bushings. The bolts in my shackle kit with rubber bushings were to long. Ask me how I know. So I cleaned up my shackles and reused them. Mine were not in bad shape.
tgifford5 is offline
post #13 of 14 (permalink) Old Apr 26th, 07, 04:35 PM
Banned
Top bolt moving around.. No by me..
It should be pretty solid in new rubber or poly, imho..
It's the botttom one that moves solidly too w/ the spring as it lengthens and shortens going up and down..
I figure you have a decent amount of play if either one move much at all!! Time for a rebuild back there for sure to me!!
pdq67
post #14 of 14 (permalink) Old Apr 26th, 07, 06:29 PM Thread Starter
bigsteve
Hi, thanks for the replys the bushings & springs are newer but the upper bushings on the shackel & bolts/nut are original and it may be time to replace the entire shackel, would like to know if the shackel kit from Ricks is a good kit, does anyone know who manufactures it or is it a over seas cheap set or does any one out there have a set that they like? thanks Steve
bigsteve is offline
DIY Network 1968 Camaro Restoration Show Brentmc Bench Racing 2 Mar 14th, 06 09:41 AM
First post!!! New 1969 Camaro owner Trakspeed Camaro Tech 6 Jan 21st, 06 06:36 AM
69 Camaro spindle & steering arm bolts 69CAMSS Brakes, Suspension & Steering 4 Jul 26th, 05 10:14 AM
5th Gen Camaro in 07? 69ProTouring Bench Racing 6 Sep 15th, 03 11:24 PM
