anyone use NPD 6 leaf springs? - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 27th, 07, 12:14 PM Thread Starter
joe
Just wondering how it sits with these springs.
balljoint is offline
post #2 of 9 (permalink) Old Apr 27th, 07, 05:47 PM
Banned
Re: anyone use NPD 6 leaf springs?
I think good old JCW sell's these too........
pdq67
post #3 of 9 (permalink) Old Jun 13th, 07, 12:06 PM
Chris
I'm going to buy and install this weekend (hopefully). If you are still interested I'll let you know how it went. I currently have Mono's with 275/60/r15 on the back that the wheel well hits when I hit a bump. I'm hoping the 6 leafs will raise the car enough and it claims you can remove leafs to adjust. We will see..........
camarojakes is offline
post #4 of 9 (permalink) Old Jun 14th, 07, 09:24 AM
Codi's Avatar
I'd be interested in hearing about your results with the 6 leaf.
Daddy's Hot Rod.
Codi is offline
post #5 of 9 (permalink) Old Jun 15th, 07, 02:27 PM
i think his results will be like the ride of a lifted dump truck, but for his sake i hope not
400bird is offline
post #6 of 9 (permalink) Old Jun 15th, 07, 03:05 PM
Dan
I think that you will not end up using all of the 6 leafs as per the directions.
It will be to harsh.
Just my opinion.
Hope it works out for you.Please give us pictures when you are done
____________________________________
good luck Dan
69 coupe, 350 crate motor/Th350c trans with 2.75 low first gear--2500 lock-up converter
Not a show car, just a part time Driver!!!
pappy's69 is offline
post #7 of 9 (permalink) Old Jun 18th, 07, 05:51 AM
Chris
I finished up the conversion this weekend. I am very happy with how it turned out. I left all 6 leafs in and It is definetly stiff but not a bad ride at all. Took a ride With 3 adults and two kids and had no issues at all. The kit was straight forward and all went together with a few minor alterations. The kit has you swap the center bolt that holds all the leafs in place with a hex head cap screw that has a shorter profile. The mono perches do not have hole that will allow the leaf to sit all the way up with a bolt head. I ground the head down just a hare and counter bored a hole in the pad with a spade bit so the head of the bolt was recessed in the pad. This made the pad sit flush in the perch.
As for height. I have 275/60/R15's on 8" rally rims on the back 225/60R15's on the front. From the ground to the bottom of the wheel well is 30.5 inches. I will try and post pictures if anyone is interested in this kit.
post #8 of 9 (permalink) Old Jun 18th, 07, 06:45 AM
Banned
I used 5/16" carriage bolts that I threaded longer and ground the squares off under the heads.
Tightened them tight and whacked heck outta them on the head to set them darn near flat to the mail leaf!
Worked fine!
pdq67
post #9 of 9 (permalink) Old Jun 18th, 07, 12:53 PM
Chris
I used the existing lower shock plates and reinstalled the existing shocks (had to extend them out). Seems to be fine??? Is this okay or should I get different shocks? longer than standard?
Hotchkis vs Global west leaf springs? Big Sky 68Z28 Brakes, Suspension & Steering 8 Feb 10th, 06 03:00 PM
Paint recommendations for Leaf springs and Sway bars ray moore Body Shop 12 Apr 30th, 05 08:07 PM
Leaf springs trouble av68 Brakes, Suspension & Steering 2 Apr 11th, 05 06:10 PM
Front Coil Springs/ Leaf Springs Speedy69 Brakes, Suspension & Steering 6 Mar 31st, 05 05:19 PM
leaf springs MY FIRST 69 Tech 2000 2 Nov 19th, 02 07:13 AM
