removing shackle bushings from frame - Team Camaro Tech
post #1 of 13 (permalink) Old Apr 28th, 07, 11:33 AM Thread Starter
bigsteve
Would like to know the best way to remove the shackle bushings from the frame. these are the originals and are stuck in there good thanks Steve
bigsteve is offline
post #2 of 13 (permalink) Old Apr 28th, 07, 12:34 PM
Banned
Re: removing shackle bushings from frame
You CUSS a lot!!
Cuss some MORE!!
Then rip them out is how I did it!!
Kinda like pulling a back molar!!
pdq67
post #3 of 13 (permalink) Old Apr 28th, 07, 01:50 PM
CDJr
pdq is right...except pulling a back molar is less painful
IIRC mine were 2-piece, and I had the tank out so I had more room.
CDJr is offline
post #4 of 13 (permalink) Old Apr 28th, 07, 02:38 PM
What a pain! I had the tank out and rigged a c-clamp to help press them out. I invented several new swear words that day...
I read where some have mentioned using a torch to burn them out...
When you get them out, others have mentioned using a brake cylinder hone to clean up the hole if there is rust in there...
His and Hers Marina blue 67's
67FamilyFun is offline
post #5 of 13 (permalink) Old Apr 28th, 07, 02:43 PM
Harry
dawg's Avatar
hmm mine just came out with out any effort.
i sprayed them with WD40 a few times and pulled them out with my hands.
434 stroker
US Navy retired
dawg is offline
post #6 of 13 (permalink) Old Apr 28th, 07, 03:11 PM
CDJr
Were they 2-piece? Or is my memory stumbling again?
CDJr is offline
post #7 of 13 (permalink) Old Apr 28th, 07, 03:21 PM
Yeah, two piece. I cut one end off with a hacksaw...then pushed the rest out with a clamp.
post #8 of 13 (permalink) Old Apr 28th, 07, 03:24 PM Thread Starter
bigsteve
I used the cut the ends off and pushed pryed with a screwdriver. Thanks Steve
bigsteve is offline
post #9 of 13 (permalink) Old Apr 28th, 07, 05:58 PM
Welcome Back - Senior Tech
Man, even my POS rust bucket's bushings practically fell out... Oh wait thats cuz there was hardly a bushing left
the learning curve is....expensive
1969 Camaro
bearcat44 is offline
post #10 of 13 (permalink) Old Apr 28th, 07, 07:09 PM
Banned
Mine were still in good shape after ALL those years, but rusted in SOLID!!
pdq67
post #11 of 13 (permalink) Old Apr 28th, 07, 07:11 PM
Fire!
But my tank was out...
Eric
Eric Kammerer is offline
post #12 of 13 (permalink) Old Apr 28th, 07, 10:35 PM
bri-rock's Avatar
After cussin' and trying the C-clamp option, I finally dropped the tank and burned them out.
bri-rock is offline
post #13 of 13 (permalink) Old Apr 29th, 07, 10:25 AM
Ted
Mine were not to hard to remove. Used a screwdriver/awl to help dig them out. Might have used channel lock pliers to turn and twist on them. But as I said mine did not cause me an issue. Once removed though clean out the holes real good and use plenty of lube when installing the new bushings.
tgifford5 is offline
Oversized Door Hinge Bushings FrankenChevy Body Shop 5 Jan 24th, 07 08:13 AM
How to change sub frame bushings MileHigh69 Brakes, Suspension & Steering 6 Feb 8th, 06 08:37 PM
Rear frame bushings for hotchkis leafs DenRS Brakes, Suspension & Steering 6 Jul 5th, 05 06:08 PM
sub frame bushings orange 68 Body Shop 4 Apr 21st, 05 07:09 AM
rear passenger frame rail and leaf mount bkt ba11 Body Shop 3 Sep 24th, 03 03:15 PM
