Help With Master Cyl. - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 29th, 07, 06:38 AM Thread Starter
i have a manual front disc rear drum brake sys.i want to convert to power brakes. i already have a booster,will i need to change the master cyl.
eddiedog is offline
post #2 of 3 (permalink) Old Apr 29th, 07, 06:52 AM
bill
Re: Help With Master Cyl.
i think you do also need to change the master. any book i looked in says power or non power master.
jaguareats is offline
post #3 of 3 (permalink) Old Apr 29th, 07, 07:25 AM
both masters are same 1" bore. Drum master has a residual pressure valve in the front section that would need to be removed to work with disks.
Power master usually has a "short hole" manual master has a "deep hole."
These things can be overcome, but probably not as easily as buying a $30 dick master at your local auto parts store.
aftermarket master cylinder ?'s bills68camaro Brakes, Suspension & Steering 2 Oct 28th, 06 09:27 PM
Master Cyl 5460465 'CT' stamp...67 Pwr drums? 67SSRSConv Tag Team 1 Mar 5th, 06 07:53 AM
C4/C5/LS1 Master Cyl question 67FamilyFun Brakes, Suspension & Steering 6 Oct 12th, 05 07:43 AM
Sleeving Z28 master cyl Mark .L.W. Brakes, Suspension & Steering 5 May 20th, 05 10:09 PM
