man gear box install - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 29th, 07, 04:21 PM Thread Starter
Steven
stamatisg1977's Avatar
hi guys after a long 8 months of sandblasting, grinding and painting i am finally putting my front end back together. i am up to the point of reinstalling my manual gearbox. how do i line everything up as to pitman arm to steering wheel and tie rods? so that when i turn the wheel it goes equal length in both directions?
thanks
Steven
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is online now
post #2 of 2 (permalink) Old Apr 29th, 07, 06:25 PM
David Pozzi
davidpozzi's Avatar
Re: man gear box install
The pitman arm should be pointing straight forward. At that point, the steering wheel should be straight and level.
davidpozzi is offline
Can't install headers with this power steering box wireman Camaro Tech 3 Nov 30th, 06 09:59 AM
Power steering gear box desertracing007 Brakes, Suspension & Steering 1 Nov 6th, 06 08:12 PM
Price Of GM Melonized Dist. Gear.. Go69 Engine 5 Sep 23rd, 06 03:01 PM
Which P/S gear box to get turnerj Brakes, Suspension & Steering 6 Dec 13th, 05 09:48 PM
Acceptable Gear Pitting PL7481 Transmission & Driveline 2 Aug 23rd, 05 04:47 PM
