Ce-2101 - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 29th, 07, 06:37 PM Thread Starter
Ce-2101
So I took off the Lakewood traction bar and removed the 4 degree wedge that kept the snubber off of the spring. Without it, the snubber was hard against the spring in a pre load condition.
The CE-2101 traction bar with the J-bolts went on with new spring pads that are urethane. The fact that the pads seem thicker and the 2101 bar is longer, I figured I wouldn't need the 4 degree wedge to keep the snubber from hard contact with the spring eye.
I was wrong.
The snubber was hard against the spring when I brought it down off the jack. So I removed the 2101 bar and I put the 4 degree wedge back in, WITH the new urethane spring pads and torqued everything back down and its still on the spring but not as compressed.
So I guess I'm going to put another wedge in, maybe an additional 2 degree wedge. That would be 6 degrees total. I just don't want preload.
So am I doing something wrong?
Doesn't it seem like a longer bar and newer thicker urethane pads would make the snubber less likely to rest against the spring? The Lakewood bar's snubber is a half inch off the spring and that was with an old collapsed rubber spring pad and a shorter bar.
mkpatrick is offline
post #2 of 9 (permalink) Old Apr 29th, 07, 07:11 PM
Banned
Re: Ce-2101
I think we are supposed to take a hacksaw to the snubbers to correct them for clearance if needed.
Right guys..
My homemade slapper's use 1/2" bolts that I can hand adjust..
pdq67
post #3 of 9 (permalink) Old Apr 29th, 07, 07:12 PM
Harley D
HarleyD67's Avatar
Re: Ce-2101
I run a 4* wedge and urethane pads with my CE's and the snubber barely touches the spring. I need to grind some off the stops or add another wedge as well.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #4 of 9 (permalink) Old Apr 29th, 07, 07:13 PM
Harley D
HarleyD67's Avatar
Re: Ce-2101
Right guys..
pdq67
correct
That is part of the adjustment allot of people forget about.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
post #5 of 9 (permalink) Old Apr 29th, 07, 10:08 PM Thread Starter
Re: Ce-2101
My rubber snubbers aren't adjustable. Does he use just bolts? No rubber snubber? Wouldn't that make for a BANG at launch?
post #6 of 9 (permalink) Old Apr 29th, 07, 10:11 PM Thread Starter
Re: Ce-2101
Will you be adding another 2* for a total of 6*?
Will that little button that goes through the hole in your wedges far enough to keep those two wedges in place?
post #7 of 9 (permalink) Old Apr 30th, 07, 09:03 AM Thread Starter
Re: Ce-2101
Anyone think its a bad idea to use two wedges to combine for a desired degree of angle?
post #8 of 9 (permalink) Old Apr 30th, 07, 09:46 AM
Codi's Avatar
Re: Ce-2101
Usually a combination of trimming the snubber and a small wedge should take care of it. I am concerned that adding more wedge will permit the axle to "windup" enough to have a severe effect on the pinion angle.
Daddy's Hot Rod.
Codi is offline
post #9 of 9 (permalink) Old Apr 30th, 07, 04:56 PM
Banned
Re: Ce-2101
Yes, just 1/2" bolts and yes, they are noisy when they slap!!
But sure easy to adjust!!
pdq67
PCV system with Edelbrock Performer (2101) GunnerV Engine 4 Mar 10th, 05 01:19 PM
